Results 1 to 2 of 2
Thread: Kenmore Series 80 - wobbles/gallops during spin cycle
    OLDINVIRGINIA is offline Member
    Feb 2007
    Virginia
    Default Kenmore Series 80 - wobbles/gallops during spin cycle
    Kenmore Series 80 Washer
    Mdl: 110. 92281100
    S/N CD0511969
    This washer is over 10 years old. This problem started a week ago. No matter how balanced the load the washer walks across the floor. I first double checked the level and found the front was a 1/2 inch lower than the back. I leveled front to back & side to side. I tried a test load and the washer still walked. Not in large jumps but at the end of the spin cycle it had moved approx. 2-3 inches. I took out the load and ran a low water only, no clothes. I did an over-ride to the top lid switch to observe the agitator/spindle/drum. I noticed when spinning, the drum was very smooth at high speed but would shimmie/wobble every couple of seconds. When the drum wobbled, it looked like it moved a good inch or more from side to side and was a REAL quick wobble. I just installed a new Kenmore washer in my rental house that I pre tested after I installed it and when I ran it through a spin cycle there was next to no movement just a little vibration. So that is how it should be working. Any suggestions to my problem?
    Sounds like your suspension pads are worn out, this link explains more about it:
    http://www.applianceaid.com/suspention.html
    Here is the ones for your model:
    Suspension pad kit
  1. Replies: 16
    Last Post: November 11th, 2007, 10:08 AM
  2. Kenmore 417 series - spin cycle banging
    By dooley in forum Sears Kenmore
    Last Post: October 12th, 2006, 11:26 PM
  3. Kenmore 80 Series - Spin Cycle half functional
    By member84 in forum Sears Kenmore
    Last Post: August 20th, 2006, 01:16 PM
  4. Replies: 3
    Last Post: August 10th, 2006, 08:30 AM
  5. Replies: 1
    Last Post: February 20th, 2006, 08:28 PM
