Results 1 to 7 of 7
Thread: Kenmore Elite Ice Spills in Bottom Freezer
    chemjaneer is offline Member
    Mar 2007
    LOUISIANA
    Question Kenmore Elite Ice Spills in Bottom Freezer
    I recently purchased a Kenmore Elite french door refrigerator and from day one the ice spills out of the ice tray into the bottom of the freezer. When you open the freezer draw ice spills into the bottom of the freezer compartment. The Sears service dept ordered a new ice swing arm that detects ice level but it was the same exact part. They say they don't have a fix, but I remember reading somewhere on internet that someone had same problem and Sears did fix by replacing icemaker. I have to believe anyone that has same refrigerator is suffering the same messy problem. Any ideas or where I should go from here? THanks
    Whats the model# of your refrigerator? its located inside the refrigerator section on the left, right, or ceiling walls.
    Mar 2007
    LOUISIANA
    Default Model # of Elite Refrigerator
    Model # 795.77542600
    Mfg Date: 2006.07
    Appreciate the help.
    Yes,
    Your refrigerator is made by LG, you will need the complete ice maker assembly:
    Manufacturer part number 5989JA0002Q is RepairClinic item number 1348347
    Mar 2007
    LOUISIANA
    Default Will replacement fix problem?
    Thanks Jake for your quick reply. I searched for my model # on the Sears parts website and found the icemaker they listed had the same part number as the icemaker part # you gave me. Do you know if the icemaker design has changed from the original? I believe that it is a design problem and replacing the icemaker will not fix my problem unless they have changed the icemaker design. I would hate to get icemaker changed and same problem continues. Do you have any additional information that would help me resolve this?
    Econo Appliance's Avatar
    Econo Appliance is offline Appliance Tech
    Jan 2007
    San Diego CA
    If your ice maker arm is the wire type which is connected to the icemaker on only one end, you can try to re-shape it or bend it to make it stick down further...
    good luck
    Econo Appliance Service - San Diego appliance repair experts!
    Yes, you can do wire re-shape, I just remember replacing alot of these ice makers, this was the #1 problem with these 795 model refrigerators.
  1. Replies: 10
    Last Post: June 23rd, 2007, 08:41 AM
  2. Kenmore Elite 106.55603400 freezer OK, refrig warm
    By Ashes in forum Sears Kenmore
    Last Post: June 19th, 2007, 10:52 PM
  3. Bad-Amanna & Kenmore Elite both w/ freezer on the bottom.
    By PPATREK in forum Maytag/Jenn-Air Reviews
    Last Post: May 11th, 2007, 08:56 PM
  4. Replies: 1
    Last Post: May 6th, 2007, 10:21 AM
  5. Kenmore Elite Bottom Freezer Fridge
    By CAMUNKI in forum Sears Kenmore
    Last Post: August 27th, 2006, 08:45 AM
