Old March 14th, 2007, 07:44 AM
maggie2853 is on a distinguished road
Default Year Old Kenmore Gas Oven Won't Light
I bought a Kenmore Gas Oven (Model #790.71054402) about a year ago and it worked well until a couple of months ago. I turned the oven on to pre-heat and realized ten minutes later that nothing was happening. One day it works and the next day it doesn't. The broiler doesn't work either. If I could figure out what was wrong I'm sure one of my son's could fix it but I don't even know where to start. I would appreciate any and all suggestions
Old March 14th, 2007, 08:44 PM
Intermittent problems like this are extremely hard to diagnose.
Possibilities: Oven thermostat, oven igniter.
Old March 15th, 2007, 02:15 AM
Question Clarifying My Message
I think maybe my first post wasn't very clear. The problem isn't intermittent. When I said that one day the oven worked and the next day it didn't I meant that it died all of a sudden. There were no problems until it just stopped working. I've tried turning it on several times since it died (guess I'm hoping it will fix itself) but absolutely nothing happens. I remember when it was working that I would see a light (not the oven light) towards the back when I turned it on and this light (I'm assuming it's the electronic ignition) isn't there now. The broiler quit working the same time the oven did. I don't know if any of this helps.
Old March 15th, 2007, 01:27 PM
If you want to fix it yourself, you will need a volt/ohm meter to start testing parts for continuity and voltage readings.
Its still going to be either one of those 2 parts I linked you to.
If you turn on your oven and you get 120 volts at your oven igniter and your igniter won't come on, then thats the bad part. If no 120 volts at the igniter, check for 120 volts at your thermostat.
Kenmore model 790.9661* oven door problem hammesd Sears Kenmore 13 October 26th, 2008 09:18 AM
Kemore elite gas range - oven light stays on all the time vkenn Sears Kenmore 2 April 11th, 2007 06:53 AM
Kenmore gas oven 362.72295790 oven won't light bandit1trucking Sears Kenmore 1 November 19th, 2006 11:36 PM
Magic Chef Gas Oven - 3110KRW svwilly Maytag/Magic Chef/Admiral/Jenn-Air 3 September 29th, 2006 04:45 AM
Kenmore 790 Gas how to fix oven light plunger panda7 Sears Kenmore 8 June 15th, 2006 11:28 PM
