Here is the problem: There is a clear plastic piece that is located just below the chute (you can see it from the outside of fridge) and is actually connected to the dispenser "paddle". Maybe Im paranoid, but it looks like it is hanging down further than before. Maybe I knocked something out of place when I cleared the blockage in the chute. I can look up thru the clear plastic peice and see ice hanging. Water is know leaking out of the chute from what appears to be melting ice from the chute. The ice maker is working fine, but the ice does not dispense as well as before and sometimes wont stop dispensing until I physically pull the dispenser paddle out with my hand and turn the dispenser to the lock position. Please help!!!! |
After looking at the ice maker more closely, it looks like the "black flap" that closes to keep the ice from coming out of the bin stays open allowing the ice to melt and leak...hope that helps to better describe my problem
Are you referring to #6 here:
http://www3.sears.com/imaging/ImageP...&titleID=00008 Thats your ice dispenser door that flaps open when you push the ice dispenser lever. Its likely you will need to order this door repair kit to fix it: Ice chute door kitJake
Thanks Jake for taking the time on Easter to help me with my problem. Yes the picture you included is the "Black Flap" I was trying to expalin. I will order it. How hard is it to install? What screws and or parts do I have to remove to get to it? Thanks again Jake!
#21 in that parts link I posted is your dispenser trim panel, it has 2 slots underneath it, get a flathead screwdriver and pop those 2 notches, then it will come off and you can see everything.
| frigidaire ice maker leak | icemanTO | Frigidaire/Electrolux | 32 | September 28th, 2008 06:25 PM |
| Ice Maker water leak in front door | trs80 | Whirlpool | 3 | June 18th, 2007 11:16 AM |
| Ice maker supply ice dam? | mlamourine | Maytag/Magic Chef/Admiral/Jenn-Air | 1 | May 23rd, 2007 10:46 PM |
| Kenmore Coldspot Ice Maker Stopped Working | Izumino | Sears Kenmore | 5 | March 11th, 2007 07:58 AM |
