Old April 12th, 2007, 09:22 AM
jakster is on a distinguished road
Unhappy Kenmore Dryer 110.76891800 won't stop running
Hey, the old thing works perfectly except that it will not stop running unless I open the door. It starts right up and drys well when I press the "Push to Start" button, but the timer never moves no matter what mode it is in.
Thanks in advance to anyone who can offer advice on how to fix this thing and where to go to get any parts I may need. (I am fairly competent with electrical and mechanical stuff.)
Old April 12th, 2007, 11:35 AM
It sounds like your timer is bad.
Old April 12th, 2007, 07:03 PM
Thanks much Jake; that's what I figured but it sure is nice to get your expert opinion before ordering a replacement part.
Old April 13th, 2007, 08:52 PM
Glad to help, and if the timer doesn't solve the issue, you can return it for a full refund within 30 days when you order it from that link.
Old April 14th, 2007, 01:57 AM
What else could it be besides the timer? Is there something else I should check before I order a new timer? Thanks again!
Old April 14th, 2007, 03:59 AM
I should mention that I do have a good DVM in my toolbox if it would be helpful to test voltages at the timer terminals, but I would need directions as to what to look for. Thanks again!
Old April 14th, 2007, 07:40 AM
With the Sears models, they don't provide a schematic online to help troubleshoot it, but from what your saying is wrong with your dryer, I would suspect the timer being bad.
Old April 14th, 2007, 11:09 AM
OK Jake, thanks again! I will order the timer and report back later with the results.
Old April 14th, 2007, 01:51 PM
BigJon38 is on a distinguished road
Default Dryer
Jake, couldn't that be the PTS button stuck closed also? I can see the timer being bad since it isn't advancing, but if the dryer runs unless door is open that would also indicate a bad PTS button wouldn't it?
Thanks for any insight!!
Jon
Old April 14th, 2007, 06:09 PM
BigJon, I don't think the PTS button is stuck closed in this case because when I stop the dryer by opening the door, if I then close the door again, the dryer does not start running until I press the PTS button again.
I'm not having any luck finding a replacement timer though so I may be SOL. (They do not have it in stock at the link provided by Jake.)
Kenmore Dryer Mod. No. 110.67832794 won't stop running mikeacfla Sears Kenmore 5 April 8th, 2007 10:31 PM
Maytag Dryer won't stop running. mrstree Maytag/Magic Chef/Admiral/Jenn-Air 6 June 28th, 2006 09:20 PM
Kenmore Dryer won't stop rodent_314 Sears Kenmore 2 May 21st, 2006 02:55 PM
Kenmore Electric Dryer Won't Stop Running WadeB Sears Kenmore 2 December 7th, 2005 06:46 PM
Kenmore Dryer won't stop running 1fahrenheit Sears Kenmore 5 July 23rd, 2005 10:29 PM
