Need help! Diapers piling up, wife's on my case.
Kenmore Elite washer (SM 9711024??) (Sorry at the office and don't have the model #, but it's the Catalyst top loader). Parts #: 3954052 Did a diagnostics test (Neutral Drain/Spin) all shows t4 but instead of draining, the water re-circulates through. Same with all speeds. Checked the gearcase and tried to clean things out, but did not see any debris. Not mechanically/electronically inclined so I have not tested the voltage measurements. If there's any way to determine what the problem is with just this info? If so would be greatly appreciated. If you can inform part, where to buy, and how to install, you would be a hero (and my wife's savior). Do not know if relevant; no particular noises (beeps, clicking, humming, etc), smells (burnt), or LEDS blinking. All it does is re-circulate the water through when it should be draining. Thanks for looking! |
Yes, we would need the model# to get the info on this washer to help you.
The model # is: 110.20056992
Ser: CJ3703316 Type: 111 Not sure, but I don't think it's the lid switch since the agitator starts when shut. Also, the water starts and stops to "re-cycle" the water when the lid opens and shuts as well. I pumped the water out once during a cycle (when it should have been draining) and it started up in the spin cycle with no water in it. Again, not mechanically inclined but when I was clearing the tubes out, I tried pushing the diaphram (?) which connects both the drain tube and re-cycle tube, and there was some resistance (spring) but it didn't feel jammed. Hope this info helps. Thanks. |
Was it this part that you pushed? The 2-way valve? Did you tilt the washer and push it from underneath, or did you take off the cabinet? Its better access if you take off the cabinet, here's a link to show you: Read#2 here: http://www.applianceaid.com/procedures.html On this model it has a 2-way valve thats mounted inside the washer on the lower rear panel. I remember replacing one of these a couple of years ago, and it fixed it. Here is the one for your model: (click photo for pricing/ordering information): Jake
Took a while, but ordered the part, replaced the part,
and all is now working well. Just wanted to say thanks! |
Sounds good, glad its working good again.
| Sears Kenmore Elite 110.20932991 washer leaks | millervt | Sears Kenmore | 3 | May 24th, 2007 08:47 AM |
| Kenmore Elite Catalyst washer won't drain & spin | Brittgee | Sears Kenmore | 1 | August 24th, 2006 02:04 PM |
| Kenmore Elite Washer with No Power | MikeF | Sears Kenmore | 1 | July 2nd, 2006 10:14 PM |
| Kenmore Elite washer broken after move | maharp | Sears Kenmore | 1 | January 17th, 2006 10:46 AM |
| Kenmore washer spins while draining | sturc | Sears Kenmore | 5 | January 1st, 2006 10:51 PM |
