Here's what I've done: (1) I did the optics test, and everything seems fine. 2 blinks when flapper is open, steady light when closed. (2) I did the "jumper" test across T&H - and was able to make the icemaker go through a full harvest cycle (after a couple of attempts), and it even dumped water after removing the jumper before the 10 o'clock position. The icemaker itself was also warm. So, I assume that the icemaker is OK. However, I've not been able to reproduce a harvest cycle using the "jumper" test. Absolutely nothing happens. The Optics test still shows a solid light when the flapper is closed, and 2 blinks when open. So, I started tracing the voltage, and what I found was the Black with white stripe wire that serves as the input into the icemaker only has a voltage reading of 65V. (there are 4 wires that lead to the icemaker- a green with yellow stripe, a pink, a white, and the black with white stripe). The black with white stripe reads 65v regardless if the flapper is open/closed, or the door switch is open/closed - all the others (white, pink, and green with yellow stripe have no voltage - which I suspected with the white (neutral) and green w/yellow stripe (ground), but not sure what the pink is for). I then went to the receiver board, and measured the black wire - which read 115v, but the black with white stripe wire at the receiver board also only read 65v. Are these 2 black with white stripe wires connected? If so, does this mean that the receiver board is bad? I'd expect the input wire to the icemaker needs to read 110v - and that something is dropping it to 65v - I'm guessing a bad receiver board. Does anyone have a schematic that shows what wires run to where for the receiver board and icemaker? Thanks, Sean |
I forgot to mention that this problem occurred around the same time I pulled out the old water filter. We have since not replaced it, as our water tastes fine. I haven't seen anything indicating that a filter is required in order to produce ice, but maybe it's something that simple. It doesn't necessary explain the 65V running to the icemaker, however.
You may have a short somewhere, I tried helping this member with a similar issue, but we were unable to resolve it.
Here is that thread: http://www.applianceblog.com/mainforums/showthread.php?t=7416 You can try to contact that member to see what final fix was. Jake
| Kenmore 106.56232400 Ice Maker Problem | Boboskedeet | Sears Kenmore | 12 | July 6th, 2007 11:01 AM |
| Yet another Superba icemaker with issues | MrT | KitchenAid | 5 | February 11th, 2007 10:28 AM |
| Icemaker Expert Needed | J_Vincent | Maytag/Magic Chef/Admiral/Jenn-Air | 4 | September 25th, 2006 02:39 PM |
| Kenmore Elite Icemaker not working | david18 | Sears Kenmore | 1 | September 9th, 2006 10:34 AM |
| Kenmore Elite S/S Water & Ice problem | exiledtiger | Sears Kenmore | 1 | September 22nd, 2005 06:51 PM |
