Results 1 to 10 of 12
Thread: Kenmore 70 Series Dryer Won't Start
    KCFaninSTL is offline Member
    May 2007
    Midwest
    Default Kenmore 70 Series Dryer Won't Start
    I've read many of the threads here, and have an idea of what might be wrong with my dryer.
    I have a Kenmore 70 Series, Model 110.68702894. The dryer has given me issues before with running for about 20 minutes then stopping. Once I clean out the vent hose and back of the dryer, it usually runs fine. I had to do this a couple of days ago, and once again the dryer was running fine. Then all of a sudden the dryer would not start, no matter the setting. If the timer is left on (set at 60) it will count down, but will not start.
    From what I've read, I believe I need to replace the thermal fuse but still need to get down there and check it out. I also have a feeling I need to clean around the motor, to ensure it's not gunked up.
    Any help is greatly appreciated! Thanks!
    Sean
    rickgburton's Avatar
    Jul 2006
    Murray, Utah, United States
    You might want to check the door switch also.
    Rick
    OWNER RICK'S APPLIANCE REPAIR
    REFRIGERATION SPECIALIST
    May 2007
    Midwest
    The door switch seems to be okay. I'm not positive about that. I'm guessing that the door switch is okay, since the only time that the timer will count down is when the door is shut, or the door switch is depressed.
    Thanks for the suggestion!
    Yes, it sounds like it may be your thermal fuse.
    You can open your dryer and jump the thermal fuse wires and see if it comes on. Unplug your dryer first before opening it.
    Here is a help link to get access to it:
    Read#18 & #19 here:
    http://www.applianceaid.com/whirlpool-dryers.html
    Here is the thermal fuse for your dryer, in case you need to order it:
    May 2007
    Midwest
    Thanks Jake!
    Now being a novice at most of this stuff, would you explain "You can open your dryer and jump the thermal fuse wires..." I'm not sure how that is done. Thanks!!
    Sean
    Read#18 & #19 here:
    Yes, its very easy, pull your dryer out away from the wall then unplug your dryer, then take your back access panel off.
    #5 in this photo is your thermal fuse. If you have an ohm meter you can test it for continuity, or if you don't have an ohm meter, you can take the 2 wires off of it, then put those 2 wires together with electrical tape, then plug your dryer in and see if its starts running.
    Here is a help link to test with an ohm meter:
    http://www.applianceaid.com/test_with_ohmmeter.html
    May 2007
    Midwest
    Thanks Jake! I'll check it out. I appreciate all the help!!!
    Glad to help Sean.
    May 2007
    Midwest
    It is the thermal fuse. Just curious... Can I safely run the dryer without the thermal fuse? I currently have it bypassed, as you suggested. Just didn't know if it was safe to do that until I get the new fuse.
    Sean
    splady60 is offline Member
    Jan 2012
    Rhode Island
    I have a Kenmore 70 Sries Gas Dryer. The timer button isn't working well. It starts but then when I take my hand away it stops. Also, it gets warm but takes forever to dry. Please HELP!!
  1. Kenmore 70 Series Electric Dryer will Not Start
    By planz in forum Sears Kenmore
    Last Post: December 4th, 2005, 05:18 PM
  2. Kenmore 70 Series Dryer Won't Start
    By julian_001 in forum Sears Kenmore
    Last Post: October 19th, 2005, 07:51 AM
  3. Kenmore 90 series dryer won't start
    By lbtnh in forum Sears Kenmore
    Last Post: September 24th, 2005, 08:15 PM
  4. Kenmore 90 series dryer won't start
    By supermancs in forum Sears Kenmore
    Last Post: June 6th, 2005, 11:27 PM
  5. Kenmore 90 Series Gas Dryer Problem
