Closed Thread
  #21
Old January 31st, 2005, 12:13 PM
NoTalent is on a distinguished road
Post imported post
Wow your husband is a lucky man!
Ok you want to make sure your multimeter is set to DC and is set to 100 (or some number that is the next step up from 48--but not lower than 48 because it will appear maxed out).
If you look at my picture at the top (just for reference, because I know yours is different) you want to touch the red probe on your Multimeter (I'll call it MM) to the "Motor RLY" lead. Then touch your black probe to the GND lead. The board should be plugged in and the dryer should be plugged in when you make this measurment.
Be careful not to touch your probe across two leads at the same time!
Old January 31st, 2005, 05:57 PM
Post imported post
Good intructionsNoTalent!
Kelly, If your abit nervous about testing the board, Since i have changed many of these boards over the years. I will just ask you a couple questions to find out if the board is bad. Or the thermistor is bad.
1st: When you push the start button on either timed or auto dry, does the dryer turn off as soon as you release the start button?
Then its the board thats out. Part#8546229
2nd: When you start the dryer on timed dry, does it run about 10-15 mintues then make 3 beeps and turn off? Or runs a couple seconds then makes 3 beeps right away, then turns off? The 3 beeps will only sound if you have the "end of cycle signal" turned on. So make sure the "end of cycle signal" is on.
If it does this, then its the thermistor thats out. Part#3976615
Let us know which one it does.
Old January 31st, 2005, 06:29 PM
kellyt is on a distinguished road
Post imported post
You guys are the greatest!
NoTalent-Thanks for your directions. I'll be an electrician before ya know it!:P
Jake - my dryer does the 1st;runs when I push the start button and immediately turns off when let go. It does that on both cycles - timed andautowithout any beeps. Thank you for the part number as well-Looks like I'm part shopping tomorrow! Do you know if that's acarried partthat the Sears parts store sells or should I try an online store?
I'll let you know how this turns out..I can't thank you enough for your time and patience! KT
  #24
Old January 31st, 2005, 07:42 PM
Post imported post
Its possible your local Sears Parts Store has it, You will have to call your local Sears Store and give them the part number, or if you live close to a Sears Store you can just drop by. Its a 50-50 chance they will have it without them having to order it.
Or you can just order it from my link, If Sears has to order it, compare prices and shipping costs and arrival time to my links provider Repair Clinic.
Thanks for your kind words Kelly!We try to help all.
Old February 1st, 2005, 04:55 AM
Post imported post
Kelly make sure you call ahead to see if they have the part. If they don't, I would compare prices (I did--and the link Jake provides has much cheaper prices than Sears and the part was here very quickly).
Good Luck!
  #26
Old February 1st, 2005, 09:31 AM
Post imported post
I decided to order it from the link on this site. Do you recommend purchasing the lifetime warranty on this board since it has a history of malfunctioning?
  #27
Old February 1st, 2005, 09:40 AM
Post imported post
Not really, since they have upgraded all the parts on this board, i have never seen the replacement board go bad. Knock on Wood.
Old February 3rd, 2005, 06:36 PM
Post imported post
Believe it or not, I've already received the part I ordered..very quick!
Now the technical questions begin! Is there a trick to getting the black wire with the gold tip disconnected from the flat silver piece? I'm afraid to pull too hard and I found myself getting a little frustrated so I thought I'd turn to the experts!
  #29
Old February 3rd, 2005, 06:53 PM
Post imported post
Glad you got the board so fast.
That black wire can be hard to get off, i use a screwdriver to pry it off, or needle nose pliers.
Good Luck.
Old February 3rd, 2005, 07:23 PM
Post imported post
Jake-I did it (thanks to you)! BUT when I run the dryerthere is a slight smell of either a new part smell or something getting warm. I was too scared to run it for long so I wouldn't burn anything up if that's not normal. Is that smell normal?
Closed Thread
Kenmore Elite Dryer Problem bdmccarty Sears Kenmore 1 June 23rd, 2006 09:44 AM
Kenmore Elite Dryer 3 beeps of death problem dogdoc Sears Kenmore 3 September 14th, 2005 07:36 AM
Kenmore Dryer 110.70052991 lint screen and beeping problem eva Sears Kenmore 2 August 19th, 2005 08:27 PM
Kenmore Dryer Problem DougP Sears Kenmore 2 June 2nd, 2005 03:38 AM
Kenmore 90 Series Gas Dryer Problem HomeRepairGreenhorn Sears Kenmore 9 March 15th, 2005 01:02 PM
