Today the fridge side of our Kenmore warmed up to about 60 degrees. The freezer side was around 15 degrees. There was barely any cold air blowing thru the diffuser so I took the back panel out of the freezer and the evaporator was pretty iced up. I melted it all with a hair dryer (I had just done this a couple months ago). I put it all back together and there was just a little more air coming out of the diffuser, but it didn't seem very cold. I ended up pulling the diffuser out in case it was sticking shut. Using an infra-red thermometer, the back wall of the freezer is 0 degrees but the vent in the top left of the fridge is 45 degrees. I don't see how the fridge could ever get down to 37 degrees that way.
Any ideas? Thanks, Denny |
Was the evaporator coils completely clogged up? Its normal for them to have a thin layer of frost on all the coils.
If your Air Diffuser wasn't sticking closed, then that should be fine. Jake
Yes the evaporator coils were completely clogged, mostly towards the bottom half. It seems to do this every 2-3 months. The fridge is cooling a little better now, but it still doesn't seem quite as cold as it should be. It's around 45-50 degrees, even though I have it down to the lowest setting - 33. The freezer is still right at 0 degrees. |
Its possible your electronic control board is intermittently malfunctioning causing it to do this, I have replaced these boards because of this too.
Here is the one for your model: Part#8201660 Electronic Control Board Jake
That's what I was afraid of.
The link you gave for the control board didn't work. Could you give it again? Thanks, Denny |
That link works for me, what happens when you click it?
It goes to http://click.linksynergy.com/fs-bin/...&type=10&subid= and says page cannot be displayed.
Thats very strange, I clicked that link and it goes right to the pricing/ordering page.
Here is another part supplier that has it: Part#8201660 Electronic Control Board Click that link and see if it works. Jake
| kenmore elite fridge side not cold | EdBurkett | Sears Kenmore | 7 | November 22nd, 2008 10:41 AM |
| Kenmore 106.72852101 Water in fridge, warm fridge | robss96dcm | Sears Kenmore | 3 | June 5th, 2007 12:06 PM |
| Kenmore side-by-side...fridge side warm but freezer side fine | jpp816 | Sears Kenmore | 18 | May 18th, 2007 11:17 AM |
| Kenmore Elite SxS warm on Fridge side | BWinMinnesota | Sears Kenmore | 3 | September 17th, 2006 11:56 PM |
| Kenmore Cold Freezer - Warm fridge Frost free failure | rkgrp | Sears Kenmore | 4 | April 4th, 2006 01:52 PM |
