Results 1 to 2 of 2
Thread: Kenmore ice and water not working
    sec78 is offline Member
    Jul 2007
    Indiana
    Default Kenmore ice and water not working
    I am having troubles with our ice maker and water dispenser on the door of our Kenmore 596.9555510. The ice maker cycles fine, but produces no ice (not getting water in the cube slots). The water dispenser will dispense water sometimes if you hold the switch for 15-20 seconds.
    I have checked the water supply line and it is fine. I also took the water line off the out side of the water valve to the water dispenser and the water will make it out of the valve after waiting as well. I'm guessing it is the water valve that needs to be replaced. Are there any additional relays or delays that I should be concerned with that might be faulty causing this long pause or is it just the valve?
    So you took off your water supply line that connects to your water inlet valve in the back, and ran it into a container and you had good pressure?
    If so, then its likely your water inlet valve.
    Here is a new one for your model:
    Part#D7742204
    Water inlet valve
  1. FIXED: Kenmore Coldspot Ice Maker Stopped Working
    Last Post: October 23rd, 2011, 11:34 AM
  2. Replies: 3
    Last Post: July 1st, 2007, 09:21 AM
  3. Replies: 9
    Last Post: May 16th, 2007, 12:45 PM
  4. Kenmore refrigerator water dispenser drips
  5. Kenmore Elite S/S Water & Ice problem
    By exiledtiger in forum Sears Kenmore
    Last Post: September 22nd, 2005, 07:51 PM
