July 11th, 2007, 12:18 AM
Kenmore Coldspot -- Dripping Water in Freezer?
Brand: Kenmore Coldspot
Model: 106.50799002
I noticed a dripping noise earlier tonight and found that it was coming from our freezer. Here is the area of the freezer that I saw water dripping:
This is located at the bottom of the freezer.
We turned the water off (behind the fridge) and it appears to have stopped dripping (although not immediately - it's been an hour since we turned it off, and it no longer drips)
Is this something that is meant to happen, and if not, what can be done to correct it?
I did try and search for an answer, but couldn't find anything that seemed to replicate this issue. Appreciate any suggestions, or otherwise.
Regards,
James
July 11th, 2007, 05:19 AM
You may have just seen the refrigerator defrosting.
The evaporator coils are located on the bottom of the back wall of the freezer section. A heater comes on to melt the frost and the water then drains into a hole and into a pan.
The refrigerator is cooling ok?
There is no standing water or ice in the bottom of the freezer section?
July 11th, 2007, 06:57 AM
Thanks for the quick reply!
Originally Posted by
technician
Yes, the freezer is doing its job and is very cold.
No, there is no standing water or ice on the bottom of the freezer.
So it would be safe to turn the water back on and pretend like none of this happened?
July 11th, 2007, 11:55 AM
Yes, just keep a eye on it.
Don't turn the water on and then leave for a week.
By Godot in forum Sears Kenmore
Last Post: February 21st, 2007, 10:50 PM
By SamIam in forum Sears Kenmore
Last Post: June 18th, 2006, 11:48 PM
By MtnMisty in forum Sears Kenmore
Last Post: September 18th, 2005, 07:16 AM
By wiggis in forum Sears Kenmore
Last Post: June 23rd, 2005, 01:38 AM
