Old July 11th, 2007, 09:11 AM
HarryJ is on a distinguished road
Default Help - Kenmore 417.40042990 Front Loading Washer Won't Spin
I have had the above model front loading washer machine for several years. I has worked very well over the years but has quit spinning. Upon removal of the back cover, I noticed the belt had come off the pulley.
I have attempted to put the belt back on the pulleys but the belt continues to spin off when centered on the two pulleys. The only way the belt does not fall off is to walk the belt about half ways off of the motor pulley. In other words only about half of the belt's surface area is on the pulley.
The belt seems to have very little displacement and shows no major sign of wear and tear.
Is it possible that the problem is with the motor bearings and not the belt itself? Is there a way for a guy who is not too "handy" to determine the root cause of the problem?
Old July 12th, 2007, 03:45 PM
When you turn the tub pulley does it seem to turn off-centered and kinda wobbles? Try to move the pulley up and down, then in and out, Do you notice any slack when doing that?
Kenmore Front Load Washer Spin Noise jhooper Sears Kenmore 1 April 24th, 2007 06:48 AM
Kenmore front loading washer - lower weight robb4359 Sears Kenmore 2 November 26th, 2006 10:03 PM
Kenmore Washer will not spin all the time a&p Sears Kenmore 5 January 23rd, 2006 10:55 PM
kenmore model 417 washer won't spin gpress Sears Kenmore 11 January 8th, 2006 11:36 PM
Kenmore Front Load Washer Won't Drain or Spin ed Sears Kenmore 3 March 20th, 2005 04:41 PM
