Page 1 of 6 123 ... LastLast
Results 1 to 10 of 52
Thread: Maytag ice maker not working
    Jun 2007
    MA
    Default Maytag ice maker not working
    Model Number: MZD2766GEB
    Brand: Maytag
    Hi, I searched the other threads discussing this and none seemed to fit except the man who's machine spontaneously started working when he went for the model number.
    Maybe that magic will work for me?
    I have a Maytag Wide by Side MZD2766GEB. The water will still dispense, but there are no longer ice cubes being made. The bar is in the down position.
    I have a water filter connected to the inflow pipes, but that has never been an issue before, but thought I'd mention it in case it's pertinant. I tried changing the filter and that did not correct anything.
    Any suggestions?
    So its not making ice at all? Feel inside your ice maker tray and see if your feel ice or water in all the cube slots.
    Jun 2007
    MA
    So its not making ice at all? Feel inside your ice maker and see if your feel ice or water in all the cube slots.
    Nope. I've pulled every last cube out of that baby. I am wondering if something is frozen, like I read in another thread? Do you have an idea of how to remove the machine? I don't want to just break something by pulling on it.
    So there was cubes in it, in all the slots?
    Taking this ice maker out is a little tricky, as this I believe this model doesn't have the 2 screws that hold the top in, it may have plastic clips, you would need to push-up a little then out to release it from the clips, then you would have 1 screw on the bottom, then unsnap the electrical connector to it.
    Apr 2008
    Round Rock TX
    Default Did this ever get resolved?
    I am having the exact same issue as described above. The ice maker seems to be frozen, or stuck. I can't tell if there is ice in the trays, not really sure where to look actually.
    I took the front panel off of the machine to see if it was moving or rotating at all. After putting a hair dryer on the unit to warm it up, thinking that would unfreeze whatever was making it stick, it actually went through one full cycle, dumped some ice and I thought we were set.
    But alas, it is back to where it was yesterday, frozen and/or not working. Any advice? Maybe I need to remove the unit and clean it?
    Quote Originally Posted by rons2112 View Post
    Whats the model# of your refrigerator? Its located inside the refrigerator section on the upper walls or ceiling.
    Apr 2008
    Round Rock TX
    The model number is MZD2766GE* I believe. The ice maker unit looks to be attached to the side wall of the freezer.
    Ok,
    What postion is the ejector blades at? pointing straight up, down, 3'oclock, 9'oclock?
    Feel inside your ice maker for cubes, are there any? full? half full? overfull?
    Whirlpool D7824706Q Replacement Icemaker - AppliancePartsPros.com
    Apr 2008
    Round Rock TX
    The prongs seem to be horizontal, level with the tray, pointing to the right, and there doesn't feel like there is any ice in the trays, but I can't quite get my fingers into all of them to check.
    When I used a hair dryer to try and thaw things out, it started to work again and the prongs went into the up position. But when they rotated back to the horizontal position, they seemed to stick again.
    I am 99% confident that there is just some ice build up or something in there, because you can sort of here the clicking noise as if it were stuck on something, similar to what you here if the tray is trying to dump, but a cube gets in the way.
    The link to the product helps. I think I will endeavor to remove the system tonight, so I can get a better look inside, and maybe thaw out whatever is in the way. If I break it, oh well, it was not working anyway
    Yea, Take the ice maker out, and look at it closely. These are abit tricky to come out as they only have plastic support clips that hold the ice maker in place, not screws like most.
    So you would need to push-up a little then out to release it from the clips, then you would have 1 screw on the bottom, then unsnap the electrical connector to it.
  1. Help! Ice Maker not working on Maytag
    By Courtney11 in forum Maytag/Magic Chef/Admiral/Jenn-Air
    Last Post: July 15th, 2014, 06:36 PM
  2. Maytag Ice Maker Not Working
    By SMerrell in forum Maytag/Magic Chef/Admiral/Jenn-Air
    Last Post: May 21st, 2013, 11:20 AM
  3. Maytag ice maker not working
    By tommy53562 in forum Maytag/Magic Chef/Admiral/Jenn-Air
    Last Post: December 26th, 2012, 06:36 PM
  4. Maytag Ice Maker not working
    By jljpirick in forum Maytag/Magic Chef/Admiral/Jenn-Air
    Last Post: April 30th, 2012, 06:29 PM
  5. Maytag Ice maker not working
    By PaulM44 in forum Maytag/Magic Chef/Admiral/Jenn-Air
    Last Post: March 1st, 2011, 12:57 PM
