Results 1 to 2 of 2
Thread: water leak, ice on bottom of freezer
    Sep 2007
    Oregon
    Default water leak, ice on bottom of freezer
    We have a Frigidaire side by side model # FRS26ZNJS. I noticed a puddle of water underneath the fridge. It seems to be leaking quite often because I usually have to wipe it up at least 1/day. Also frozen water has collected on the bottom of the freezer.
    The fridge has a water and ice dispenser in the door of the freezer side. We shut off water to the dispenser and the problem continued.
    Any idea on what might be causing this? Not sure how to access the bottom side of the freezer to see what is going on...
    Thanks in advance for helping with our problem!
    Sounds like your defrost drain line is clogged, take all your food out of the freezer, then take off the lower back panel inside the freezer, then you will see a drain hole on the bottom below your evaporator coils, it made be iced-up, just get a hair dryer and hot water to melt it, then get something to run down the drain line.
    I use a evaporator cooler spider snake:
    http://www.azpartsmaster.com/shopazp...LR4690%29.html
    They are used basically in Arizona to clean out the water pump tubes that run to the cooler pads.
    I don't know if they would sell them in your area, but if you go to your local hardware store, they should have something similar to run down your drain to clean it completely out.
  1. Water leak in freezer
    By kent115 in forum GE/Hotpoint
    Last Post: October 24th, 2007, 12:39 PM
  2. Water leaking around bottom of freezer door.
    By darrellx in forum Maytag/Magic Chef/Admiral/Jenn-Air
    Last Post: September 4th, 2007, 03:46 PM
  3. Amana Ice Maker Water Leak
    By chevy_lumina in forum Amana
    Last Post: August 14th, 2007, 10:23 PM
  4. Kenmore fridge bottom freezing; freezer warm; no water
    By bkmason in forum Sears Kenmore
    Last Post: May 28th, 2007, 11:00 AM
  5. Kenmore Elite Ice Spills in Bottom Freezer
    By chemjaneer in forum Sears Kenmore
    Last Post: March 8th, 2007, 10:29 PM
