Results 1 to 5 of 5
Thread: Maytag MDB7600AWW Blinking '9'
    Sep 2007
    Ontario
    Default Maytag MDB7600AWW Blinking '9'
    I have a Maytag Dishwasher MDB7600AWW that displays "Rinse" light and the number 9 in the control panel. I assume this is a fault code. What does this code mean and how do I fix it?
    Further I have trouble getting the unit to cycle. It will stop and revert to the error above.
    Jul 2006
    I couldn't find that model #. Try this link for error codes http://www.repairclinic.com/referral.asp?R=1265&P=176
    Rick
    OWNER RICK'S APPLIANCE REPAIR
    REFRIGERATION SPECIALIST
    Sep 2007
    Ontario
    Rick, The Dishwasher is a Maytag Quiet 300 Series. I have checked all the Maytag error codes in the link and the closest seems to be that a '9' implies something with the door. But the door seems to work, unless if the switch doesn't work right, the error code shows. However the cycles are messed up from time to time and it's difficult to get a proper cycle.
    Any Ideas?
    Jul 2006
    Still no luck with that model number. For some reason we have a hard time looking up Canadian models here in the lower 48. If this model uses an electronic control board, I would suspect that is where the problem is. Wish I could be more help.
    Rick
    I found your model#, but I don't see "Rinse" light and the number 9 error code anywhere online.
    If you take off your lower access panel below the door, you should see the diagnostics service sheet.
  1. Maytag Neptune 8700 repair issues & Maytag Rant.
    By jazzman_q in forum Maytag/Jenn-Air Reviews
    Last Post: May 19th, 2009, 11:40 AM
  2. Maytag Dishwasher Constant Blinking Light
    By Memodos in forum Maytag/Magic Chef/Admiral/Jenn-Air
    Last Post: July 10th, 2007, 08:33 AM
  3. Maytag Dishwasher MDB6100AWW blinking display lights and won't run?
    By chip718 in forum Maytag/Magic Chef/Admiral/Jenn-Air
    Last Post: May 10th, 2007, 10:43 AM
  4. Maytag Dishwasher Blinking Lights
    By lccow in forum Maytag/Magic Chef/Admiral/Jenn-Air
    Last Post: February 19th, 2006, 02:35 PM
  5. Maytag Wide By Side - Compressor dies after 11 months
    By pete_nc in forum Maytag/Magic Chef/Admiral/Jenn-Air
    Last Post: August 16th, 2005, 10:24 AM
