Results 1 to 7 of 7
Thread: freezer shuts off after 5-7 seconds
    Sep 2007
    Anchorage Alaska
    Default freezer shuts off after 5-7 seconds
    I have a 7-8 year old, large Sears chest freezer. The temperature alarm started going off the other day and I noted that things were not as frozen as they should be. When I unplug the unit, then plug it back in, it runs for 5-7 seconds then shuts off again. If I wait a while I can get it to do the same thing again. I took the cover off the motor area and at a glance nothing is obviously wrong.
    Jul 2006
    Hi palmerfly,
    It sounds like the compressor isn't comming on. If you are hearing a "click" sound every few seconds, the overload and relay could be bad or the compressor itself could be bad. Does the compressor eventualy turn on? I'll need your model number.
    Rick
    OWNER RICK'S APPLIANCE REPAIR
    REFRIGERATION SPECIALIST
    Sep 2007
    Anchorage Alaska
    Thanks for the reply. The compressor does come on. Makes the regular, unique compressor noise that a fridge and freezer make when starting. Sounds normal. It only stays on for 5-7 seconds, then clicks off. I wrote the model number down at home, and I am not at home right now. It is a Sears, largest chest freezer they had about 7 - 8 years ago. Just guessing, but the number may have been: 253.9183511 ??? Could it be the thermostat, or some type of switching device? Thanks again for replying.
    Palmerfly
    Jul 2006
    Hi palmerfly,
    It could be the cold control. To check it, take the two wires off of the cold control (thermostat) and jump them together. See if the compressor stays running.
    Rick
    Sep 2007
    Anchorage Alaska
    Thanks for the note. I bridged two of the 3 connectors on the thermostat with a short jumper wire. The compressor fired right up, then quit after about 5 seconds just as before. Do you have any other ideas?
    Thanks, Palmerfly
    Jul 2006
    Back to my original post, either the relay and overload is bad or the compressor is bad.
    Rick
    Sep 2007
    Maryland
    Smile
    I would check the compressor thermal overload. When the compressor gets to hot the overload protects the compressor from causing internal damage.
    IceMonster
  1. Bottom freezer model 596
    By dms in forum Sears Kenmore
    Last Post: October 28th, 2013, 10:40 PM
  2. Why is there a heater in my freezer?
    By Lillian in forum GE/Hotpoint
    Last Post: April 9th, 2007, 07:03 PM
  3. Kenmore Coldspot Freezer Back-Panel Removal
    By Godot in forum Sears Kenmore
    Last Post: February 21st, 2007, 11:50 PM
  4. Replies: 4
    Last Post: April 4th, 2006, 01:52 PM
  5. Dryer runs for about 3 seconds and shuts off
    By chucklesss in forum Sears Kenmore
    Last Post: December 29th, 2005, 12:01 AM
