Page 1 of 4 123 ... LastLast
Results 1 to 10 of 35
Thread: Kenmore Range F10 error
    Sep 2007
    Inman, SC
    Smile Kenmore Range F10 error
    Model Number: 790.96123402
    I have a Kenmore model #790.96123402 Electric Range that displayed a F10 error while using the oven. I see that the code may mean Runaway Temperature (I saw a code list on another blog?). Does anyone know what needs to be replaced/repaired to correct the problem? The range was installed by my builder 3 years ago and I was not offered an extended warranty. Please help!
    I would first pull your range out from the wall, unplug your range, then take off the back access panel and ohm your oven sensor.
    It should ohm out at 1100 ohms at room temperature.
    If that checks good, then your control board is the problem.
    Here's the oven sensor probe for your model:
    Part#316217001
    Here's your control board:
    Part#316418208
    Sep 2007
    Inman, SC
    Default Kenmore Range**F10 error
    Thanks and I will try this to see how it checks out.
    Ok, sounds good, let us know the outcome.
    Sep 2007
    Inman, SC
    Default Kenmore #790.96123402 Range F30 error
    The F10 Error is fixed and now (months later) it gives a F30 error. Any suggestions on repair?
    F30 - OPEN PROBE CONNECTION
    Check all your wire connectors/connections in the back of your range, you'll need to unplug or turn the breaker off to your range, then take off the back access panel, thats where most of your wiring is located.
    Check your oven sensor probe connection as well:
    Part#316217001
    Sep 2011
    Bedford VA
    Hello. I have the same code, and bought the sensor. It didn't help, so know I'm thinking the control board is the culprit. When I turn the oven on, say 380 deg. F., the broiler comes on (top of oven) instead of the bottom element. It then heats way up (burning smell) and finally faults out. Do the experts here think this still sounds like the control board, or could there be something else I need to check? Thanks for any and all help!
    Yes, its your clock oven control board thats bad.
    Whats the model# of your range?
    Click here to locate it.
    Sep 2011
    Bedford VA
    Thumbs up
    It is 790.96119409. I found it here: bafiltersupply.com/Genuine-Frigidaire-Oven-Stove-Range-Electronic-Control-Clock-316557118_p_660.html for half of the price Sears wanted.
    Yes, but read their return policy, you can't get a refund if it doesn't fix the problem.
    When you order parts through our site you have a 365 day warranty on all parts whether it fixes it or not.
    Here's the clock/oven control assembly for your model you can order here:
    Oven Control Board 316557118 Order now for same day shipping. 365 day return policy. RepairClinic.com
  1. Kenmore Range Elite error msg. F7
    By gloria in forum Sears Kenmore
    Last Post: December 13th, 2012, 06:42 PM
  2. Kenmore Range F13 error
    By jhigh in forum Sears Kenmore
    Last Post: November 2nd, 2010, 12:55 PM
  3. Kenmore range - error code f9
    By pschumac in forum Sears Kenmore
    Last Post: July 1st, 2006, 02:35 PM
  4. Kenmore gas range 665.750141 PF error
    By lilli in forum Sears Kenmore
    Last Post: May 29th, 2006, 12:45 PM
  5. Kenmore Range Error Code F1
    By swatkins38 in forum Sears Kenmore
    Last Post: January 23rd, 2006, 02:14 AM
