Page 1 of 3 123 LastLast
Results 1 to 10 of 21
Thread: KUDS01FLBL6 - Blinking Clean Light Issue
    Oct 2007
    Southern California
    Default KUDS01FLBL6 - Blinking Clean Light Issue
    I have a Kitchenaid Superba KUDS01FLBL6 with the common clean light blinking seven times.
    I've tried some of the fixes but it's not really clear which keys on my model I need to do in sequence. Below are my panel settings in order from left to right.
    I've tried pushing "sani rinse" + "energy saver dry" + "sani rinse" + "energy saver dry" and that results in making all the lights blink so obviously, that's not correct.
    Cycles
    Baked on Glassware - Normal - Light/China - Quick Clean up - Rinse Only
    Options
    Hi Temp Scrub - Sani Rinse - Energy Saver Dry - 4 Hour Delay
    Start - Cancel
    Thanks in advance for any assistance you can offer. The dishwasher is about three years old and like others, has worked flawlessly in that time up to now.
    Mike
    Oct 2007
    Southern California
    Default KUDS01FLBL6 blinking light Issue
    Welp, I think that key combination was it. On a lark, I left it at that all blinking mode and it seems to have fixed itself. I am testing now to make sure it really is fixed and doesn't require a heating element replacement.
    Is that a difficult replacement?
    Mike
    Yes, thats the correct diagnostics mode buttons.
    To test your element, just put it in the diagnostics mode and let it run through, when the test is over, drip some water over the element, it should sizzle, if its not hot with no sizzle, then ohm out the element.
    You can pull your dishwasher out, then you can easily get to your heating element terminals to ohm it and change it if its bad.
    Here's the heating element for your model:
    Part#8537057
    Oct 2007
    Southern California
    Default Kitchenaid Superba KUDS01FLBL6
    Thanks Jake for the info.
    The ohm test is simply for continuity right? A good element will not have continuity right or is it the other way around? Also the dishwasher goes right back into blinking mode and the element is not hot after the test.
    Does the dishwasher have to pulled out for the replacement of the heating element?
    Mike
    Yes, the ohm test is to check for continuity.
    A good element will have continuity. Usually elements are good with 30 ohms or less shown on a ohm meter.
    Yes, you can get real good access to the heating element terminals by pulling your dishwasher out.
    Oct 2007
    Southern California
    Default Heating Element
    I noticed that part number is a different one than what comes up when I search for the part manually. Is a Whirlpool part compatible with a KitchenAid product?
    1164450 = This is the part number I keep getting.
    Mike
    I posted a link to your heating element in post#3, its the one for your model, it may have changed part numbers, lots do, but its still the original part for your model.
    Whirlpool owns KitchenAid so the part is compatible.
    Oct 2007
    Southern California
    Default Blinking light issue
    Thanks Jake,
    I figured it might be something like that.
    I will order it up tonight as my wife is freaking w/o the dishwasher. ;-)
    Mike
    Sounds good Mike, let us know the outcome.
    Oct 2007
    Southern California
    Default Heater Element Arrived
    Wow, the element arrived already after being shipped on Tuesday.
    A couple of questions:
    1. What tools do I need to do the install
    2. Is it necessary to pull the dishwasher out to install the element.
    3. Is there a step by step howto on how to perform the removal and install of the new element?
    Thanks in advance,
    Mike
  1. FIXED: GE quiet power III blinking light issue
    By specktiger in forum GE/Hotpoint
    Last Post: October 27th, 2010, 12:45 PM
  2. KUDP more questions for clean light blinking
    By Gradstudent in forum KitchenAid
    Last Post: March 23rd, 2007, 11:10 PM
  3. clean blinking light kudp01flss6
    By allyoops in forum KitchenAid
    Last Post: May 10th, 2006, 12:16 PM
  4. Blinking Clean Light
    By JJTERRY in forum Whirlpool/Roper/Estate
    Last Post: December 31st, 2005, 12:24 PM
  5. Kenmore Elite 665.17269401 clean light blinking
    By jdoty in forum Sears Kenmore
    Last Post: October 1st, 2005, 08:49 PM
