Results 1 to 8 of 8
Thread: GE Icemaker not dispensing ice.
    Oct 2007
    Miami
    Default GE Icemaker not dispensing ice.
    I have a GE fridge Model #GSS22JEMDWW. The other day the ice maker stopped dispensing ice. It makes ice fine and dispenses water as well. However, when I tried to turn the arm/motor, it will not turn. Any suggestions? Thanks for any help you can provide.
    Rob
    Oct 2005
    Wichita Falls, Texas USA
    Arrow
    Most likely frozen up, known problems with this on GE....try removing the auger motor and thawing it to see if it will then run...there are boot kits to install over the motors to prevent this or just put it into a plastic zip lock bag with the shaft poking thru a hole in the front...
    Oct 2007
    Miami
    Thanks for all your help!!! Problem fixed.
    Oct 2005
    Arrow
    Cool...thanks for posting back...
    Jun 2011
    Miami
    How do I test the auger motor before I remove it and thawing it to see if it will then run for me? I have the same problem, please help
    Quote Originally Posted by angelfig View Post
    Whats the model# of your refrigerator?
    Click here to locate it.
    Jun 2011
    Miami
    here is the model # GSS22JEMDWW
    Your auger motor may be frozen, use a hair dryer on it and see if it starts turning again.
    Here's the auger motor for your model you can order, if still won't turn after your thaw it out:
    Manufacturer part number WR60X10258 is RepairClinic item number 1394066
    The best, if not easiest way to access the auger motor is pull it out. It's just four screws, two on each side of the fork assembly. The white plate and auger motor will come out together. There is a quick disconnect for the wires (Pulls apart).
  1. Kenmore Coldspot ice maker not dispensing ice
    By 1der in forum Sears Kenmore
    Last Post: September 2nd, 2012, 10:58 AM
  2. Replies: 16
    Last Post: November 28th, 2011, 09:51 PM
  3. Icemaker slow in dispensing
    By jpickett in forum Frigidaire/Electrolux
    Last Post: October 14th, 2007, 11:45 AM
  4. Kenmore elite not dispensing ice
    By dkap in forum Sears Kenmore
    Last Post: April 13th, 2007, 09:44 PM
  5. Replies: 2
    Last Post: April 5th, 2005, 04:25 PM
