Results 1 to 4 of 4
Thread: ED22DQ freezer coil red hot
    Aug 2005
    Default ED22DQ freezer coil red hot
    Hello,
    I have this coil that can be seen behind bottom basket in freezer side that gets red hot at times. I noticed it tonight from a sound of water drops hitting it and steaming off instantly. Is this a normal process or should I investigate more?
    Fred
    Oct 2004
    A copy.....
    **I heard a sizzling noise inside my refrigerator and it looked like something on fire when I opened the freezer door. What should I do?
    There are defrost heaters imbedded in the evaporator coil in your refrigerator to defrost the coil after an accumulated period of running time of the compressor. You were probably seeing and hearing the refrigerator in a defrost cycle. Since you unplugged the refrigerator, the coil is now defrosted and if you plug it back in, you will not hear this sound. In fact, the refrigerator will not run because it is probably still in defrost. So plug it back in, let it sit until it starts running and cooling. I have made many service calls for this identical situation. Don't be afraid to plug it back in. Turn it off at control, plug in, and turn control back on. If there is something actually wrong, you can unplug it again.**
    http://www.applianceaid.com/
    Appliance Repair Aid
    Aug 2005
    thanks jeff , I thought it might have something to do with defrost cycle since its a fairly new fridge.
    Oct 2004
    Your welcome!
  1. Kenmore s/s hot between fridge and freezer
    By d213rr in forum Sears Kenmore
    Last Post: July 28th, 2007, 12:28 AM
  2. Sides of freezer are very hot
    By badonkadonk in forum Sears Kenmore
    Last Post: May 14th, 2007, 10:29 AM
  3. Why is there a heater in my freezer?
    By Lillian in forum GE/Hotpoint
    Last Post: April 9th, 2007, 07:03 PM
  4. Replies: 1
    Last Post: December 5th, 2005, 10:06 AM
  5. Replies: 3
    Last Post: June 23rd, 2005, 02:38 AM
