Results 1 to 4 of 4
Thread: Maytag Gemini f9-5
    Oct 2007
    mount vernon wa
    Default Maytag Gemini f9-5
    I have a maytag gemini #mer6772bac that is giving me f9-5 error. After unpluging (to clear code) and plugging back in, lower latch will try to lock 3 times and then throw the error code again. I can get stove to start heating up before it throws the code. Is is a control board problem or lower latch?
    Craig
    Here's what that code says:
    F9:-5
    Latch Unlock Lower
    Check for obstruction in door lock mechanism
    Check your lock latch assembly or metal latch lever for obstruction in door and make sure the lever isn't bent out of place.
    Nov 2011
    Waukee, IA
    We have the same problem with our Maytag Range (Gemini) - Model # MER6772BAS. My question is that the whole range is now locked and this does not allow us to use the Upper oven. Is there a way to RESET the error code so we can atleast use the upper oven until repaired.?
    I'm not sure how to access the lock latch assembly for this model, you'll need to get Maytag to come out to do it.
    Unless another tech. or member knows.
  1. Maytag Neptune 8700 repair issues & Maytag Rant.
    By jazzman_q in forum Maytag/Jenn-Air Reviews
    Last Post: May 19th, 2009, 11:40 AM
  2. Maytag Gemini
    By pebbles in forum Maytag/Magic Chef/Admiral/Jenn-Air
    Last Post: October 2nd, 2007, 12:30 PM
  3. Maytag Gemini MER6772BAW
    By budman in forum Maytag/Magic Chef/Admiral/Jenn-Air
    Last Post: July 26th, 2007, 01:15 AM
  4. burner out - Maytag Gemini w/Ceran top
    By wrench_challenged in forum Maytag/Magic Chef/Admiral/Jenn-Air
    Last Post: November 16th, 2006, 01:58 AM
  5. Maytag Gemini Door Lock
    By Brandy Marie in forum Maytag/Magic Chef/Admiral/Jenn-Air
    Last Post: July 26th, 2006, 08:29 PM
