Results 1 to 4 of 4
Thread: Water leaking from side by side Frigidaire
    Aug 2005
    Default Water leaking from side by side Frigidaire
    Just recently moved and found out the Frigidaire side by side ref leaks on the bottom right side.
    It only leaks once we use the water or ice dispenser. Checked water hose from wall and all was well. Found source of water was from the part where the small water tubing went up back of ref.
    My question is, how do I open the back side of ref to change out the water tubing? I tried looking for the opening but shows nothing. Friend I asked before said I may need to open from front (inside ref). Is this right?
    Is there a website that shows exactly how to go about this?
    Oct 2004
    G'day,
    Not likely.
    Into the FF section or the FZ section?
    You don't.
    Model# is ?
    http://www.applianceaid.com/model.html Some model# helps.
    Appliance Repair Aid
    Aug 2005
    What did you mean by FF or FZ section? Apologize for my ignorance in this.
    The model number for the Frigidaire is MRS22WNGW7
    Its a side by side with water and ice dispenser on the freezer side.
    I looked again into the back portion just now and saw the following:
    Water main pipe attached into the ref valve.
    From valve, it splits into 2 small white tubing.
    One tubing went to the freezer side and one went inside ref side.
    Another tubing came back down and went forward towards the ref side.
    And when i use water or ice, the water leaks from where the white tubing went into and out from ref side.
    Hope the above explanation was clear. Looking forward to fixing my problem.
    Oct 2004
    G'day,
    FF - Fresh Food section
    FZ - Freezer section
    I couldn't find on parts breakdown....does this unit have a filter?
    Check for cracked split tubing into and out of the water reservour tank....or a cracked split water reservoir tank itself. The water tank is behind the lower crispers in the FF section.
    These lines really just run through the cabinet walls and not into them.
  1. side by side frigidaire FRS22ZRF water leak
    By mpage in forum Frigidaire/Electrolux
    Last Post: May 18th, 2007, 01:28 PM
  2. Frigidaire Gallery Side by Side flooded kitchen
    By sandalwood36 in forum Frigidaire/Electrolux
    Last Post: January 26th, 2007, 01:30 PM
  3. GE GSS25WGPH side by side leaking water.
    By sallyjowv in forum GE/Hotpoint
    Last Post: October 3rd, 2006, 06:22 PM
  4. water leaking from top of freezer GE side by side
    By Norman in forum GE/Hotpoint
    Last Post: August 15th, 2006, 12:17 PM
  5. Frigidaire side by side leaking on FF side
    By sacju in forum Frigidaire/Electrolux
    Last Post: October 25th, 2005, 02:25 AM
