Results 1 to 6 of 6
Thread: Kenmore 90 Series 110.28912790--Won't Spin or drain
    Oct 2007
    United States
    Default Kenmore 90 Series 110.28912790--Won't Spin or drain
    My washer had been working just fine until last week on a load when it hit the rinse cycle the machine would not drain and it began making a very fast clicking sound. After I manually drained the machine and removed the housing. I took the impeller off and it appears to be in good shape, although it is a little hard to turn, there did not appear to be anything stuck in it. I stopped my exploration there and started looking through the forum posts. I have seen several posts that describe similar symptoms, but was not sure what to do next. I did not want to start tearing the thing apart if I did not need to. I would appreciate any ideas or suggestions on what my next move should be.
    When you say impeller, is that your water pump impeller or your motor coupling that your referring to?
    Read #2, #4, #5, #6 here:
    http://www.applianceaid.com/procedures.html
    Oct 2007
    United States
    Default Found my problem
    I appreciate your response, I decided to forge ahead and dig into the machine. My motor coupling was broken on the motor side of the coupling. Is there anything else I should consider replacing while I have the machine torn apart?
    Nope, that should do it.
    Glad you found it was your motor coupling.
    Here's the one for your model, in case others need to order it as well:
    Drive motor to transmission coupling, replaces all previous styles and versions. (for direct-drive washers with no belt)
    Oct 2007
    United States
    Thanks Jake, I appreiate your help. I will let you know how the repair goes.
    Ok, sounds good.
  1. FIXED: Kenmore 80 Series Overflow, No spin, No Drain
    By Lilljedahls in forum Sears Kenmore
    Last Post: March 3rd, 2014, 10:53 AM
  2. Kenmore 70 Series - Belt Driven, Spin & Drain Issues
    By DaveTF01 in forum Sears Kenmore
    Last Post: July 12th, 2007, 06:11 PM
  3. Replies: 4
    Last Post: August 24th, 2006, 04:57 PM
  4. Replies: 8
    Last Post: July 12th, 2006, 12:22 AM
  5. Kenmore 70 series hums, wont spin or drain or agitate
    By arnierobert in forum Sears Kenmore
    Last Post: November 22nd, 2005, 04:13 PM
