Results 1 to 6 of 6
Thread: Kenmore gas range - oven burners won't light
    Sep 2005
    Detroit
    Default Kenmore gas range - oven burners won't light
    I have a Kenmore gas range/oven, approximately 7 years old. Unfortunately I don't have a model number with me right now. We recently moved to a different house and when we hooked it up after moving it, the burners in the oven won't light. The burners on the stove top ignite sometimes, but other times I have to light them with a lighter (about a 50/50 chance that I have to light them manually).
    When I turn the oven on to preheat or bake, it clicks like it normally would when it was working properly at the other house. I removed the panel from the oven floor to take a look, and the ignitor glows red, the burners just won't ignite. I don't smell gas at all in the oven when those burners don't ignite, but I DO if the stove top burners don't.
    The only thing different between the two houses is that the supply line at the old house was 3/4" and the supply line at the new house is 1/2".
    Any suggestions for now? I'll look for the part number this evening.
    We would need the model# of your range.
    If the oven igniter glow bar is glowing red and the gas doesn't start coming out after 2 minutes, thats usually a sign of a bad/weak glow bar.
    Sep 2005
    Detroit
    This thread should be moved to the Kitchenaid forum...my mistake, sorry mods!
    The model number is FGF374CCSB.
    Sorry for the delay, its been very busy.
    That model# you posted is a Frigidaire.
    Is that what you have?
    Jan 2012
    Johnstown, Pennsylvania, United States
    ok jake a frididaire model fgf374ccsb wads used as a propaine stove we need it to work on natural gas what do we need to do? it was given to a friend of mine and we are trying to get it working with out haveing to pay 75+dollars for a repairman i know i had a stove it was just closeing a few air ports and it would work
    You will need to order the original orifices if the original owner didn't save them when it was converted from Natural to LP.
    Here's the original ones you can order(order 3 for the small burners):
    Orifice 5303210090 Order now for same day shipping. 365 day return policy. RepairClinic.com
    And 1 for the large burner:
    Orifice 316010804 Order now for same day shipping. 365 day return policy. RepairClinic.com
    You will then need to turn the plastic piece over in your gas regulator as seen here:
    http://www.applianceaid.com/newpics/frigconversion2.JPG
    And also the burner spud on the oven valve as seen here:
    http://www.applianceaid.com/newpics/frigconversion4.JPG
  1. Kenmore gas oven slow to heat up
    By t7044wa in forum Sears Kenmore
    Last Post: June 23rd, 2016, 07:58 PM
  2. Simple Kenmore range: burners won't turn on, light does
    By thinkmassive in forum Sears Kenmore
    Last Post: August 3rd, 2007, 10:46 AM
  3. Replies: 2
    Last Post: April 11th, 2007, 08:53 AM
  4. Year Old Kenmore Gas Oven Won't Light
    By maggie2853 in forum Sears Kenmore
    Last Post: March 15th, 2007, 03:27 PM
  5. Kenmore gas oven 362.72295790 oven won't light
    By bandit1trucking in forum Sears Kenmore
    Last Post: November 20th, 2006, 01:36 AM
