Results 1 to 2 of 2
Thread: Kenmore Elite 110.63932101 Back Panel Off?
    Aug 2005
    Woodstock, GA
    Default Kenmore Elite 110.63932101 Back Panel Off?
    I'm frustrated! About a month ago our 3-year old Even Heat Kenmore Elite dryer had the dryer-won't-stay-on-when-I-release-the-start-button problem. I removed the exhaust ducting, cleaned it out, checked the exhaust port inside the dryer, and replaced and repositioned the ducting in the rear. This solved the problem. and everything was fine for 2 weeks. Now we have a "new" problem -- the dryer won't heat. My wife has run the dryer without the ducting in place, but there is still no heat. I've decided to check all the potential problems that I've read about on this and other forums (thermal fuse, thermostats, heating coil, and then maybe the circuit board); however, I can't remove the back panel. I have removed all the nut screws, the pin that holds the exhaust duct in place, and the top panel from over the back panel. However, there appears to be about six places that are notched, glued, or perhaps riveted in place that I can't budge. Running a putty knife down the bottom and edges won't release the panel. The DIY Repair Manual doesn't address the procedure. In my frustration, am I missing something simple? How do I get the back panel off? Help, please...
    Oct 2004
    Should go through from the front....
    http://www.applianceaid.com/whirlpool-dryers.html#four
    Appliance Repair Aid
  1. Kenmore Elite Dryer 110.60092991 - Constant Beeping
    By rbusch in forum Sears Kenmore
    Last Post: October 22nd, 2007, 01:59 AM
  2. Kenmore Elite 665.17462300 keypad panel
    By rleist in forum Sears Kenmore
    Last Post: September 7th, 2006, 12:07 PM
  3. Kenmore Elite 110.60052991 Panel Buttons Stop Working
    By Jofelior in forum Sears Kenmore
    Last Post: March 20th, 2006, 01:08 PM
  4. Kenmore Elite w/touch panel
    By BaseballMom in forum Sears Kenmore
    Last Post: December 1st, 2005, 08:30 PM
  5. Kenmore Elite 110.63932101
    By hazydaze in forum Sears Kenmore
    Last Post: May 9th, 2005, 12:12 AM
