Results 1 to 8 of 8
Thread: Quiet Partner I - blinking clean light
    Nov 2007
    Dallas, TX
    Default Quiet Partner I - blinking clean light
    My QPI is currently stuck in a blinking clean loop. I have cut power to the unit to try to hard reboot to no avail. Hitting cancel just starts the drain cycle and even when I get that cleared it doesn't allow for the next load to start washing. How do I reset this dishwasher?
    Whats the model# of your dishwasher? Its located inside the door.
    Here's the thread that explains the blinking clean light:
    http://www.applianceblog.com/mainfor...ead.php?t=5671
    Your Whirlpool is identical to the KitchenAid in that thread.
    Nov 2011
    b-dale
    I have the 7 blinking lights also. The water in the washer is lukewarm not hot and the heating element is not warm to the touch. I would think that the element should at least be warm if not hot. Correct?
    Quote Originally Posted by rickster View Post
    Thats correct.
    We need the model# of your dishwasher.
    Click here to locate it.
    Nov 2011
    b-dale
    it is a Whirlpool du1148xtp. I did the open door, high temp wash/heated dry-repeat, close door/cancel many times and did get it to run one full cycle on normal with heated dry. but I have gotten the blinking clean on several other attempts. As I stated before I can touch the heating element with my finger and it does not feel hot. Also realized this post is for QP-1 and mine is a QP-2 if that matters.
    Thanks, but your still missing some digits after the "p" at the end of your model#.
    This video explains about it:
    You can ohm your heating element as well.
    Here's the heating element for your model you can order here:
    Manufacturer part#W10134009 is RepairClinic item#1381534
    W10134009
    Here's a video to access/change it:
    Keep us posted.
    Nov 2011
    b-dale
    maybe a B1 or a 81 pretty hard to read.
    Ok Its a B1 after the p. So your model# is du1148xtpb1.
    Yours uses the heater I posted just above, go ahead and ohm it per that video.
    Also feel the element, if it has bumps/pits in it, its definitely bad.
  1. Quiet Partner II Clean Light Flashing
    By jacobm111 in forum Whirlpool/Roper/Estate
    Last Post: October 14th, 2007, 02:17 PM
  2. Whirlpool Quiet Partner 1 blinking light
    By atticus345 in forum Whirlpool/Roper/Estate
    Last Post: July 9th, 2007, 01:53 PM
  3. Quiet Partner III - Blinking Light and no action
    By donewithwhirlpool in forum Whirlpool/Roper/Estate
    Last Post: July 7th, 2007, 12:18 PM
  4. KUDP more questions for clean light blinking
    By Gradstudent in forum KitchenAid
    Last Post: March 23rd, 2007, 11:10 PM
  5. Whirlpool Quiet Partner I DU1055XTPS3 - clean light flashing
    By dazedandconfused in forum Whirlpool/Roper/Estate
    Last Post: December 13th, 2006, 02:11 AM
