Results 1 to 10 of 10
Thread: Whirlpool gold accubake error E2 & F3
    Nov 2007
    Gresham,Or
    Default Whirlpool gold accubake error E2 & F3
    Model Number: GW395LEGQ3
    these error messages happen all the time at the same time E2 F3 and its to the point we cant bake anything. It does it when its preheating or when we haven't cooked anything at all....sometimes it goes off by its self when the oven hasn't been touched in 8+ hrs...cold as can be. We are obveously approching the holidays and are wondering if we can fix this issue ourselves at a less expensive approch then buying another oven. We have read bad reviews on this oven so we are concerned this problem wont be resolved.
    We also need an oven ...please anyone that can help us
    Whats the model# of your oven? Its located inside the door or on the bottom frame.
    Nov 2007
    Gresham,Or
    HI ~ thank you I didn't know where to look last night...it is model # 9752834a
    Nov 2007
    Gresham,Or
    SORRY wrong numbers...here is the model number: GW395LEGQ3
    I am hoping to fix this soon, any help would be wonderful.
    Here's the service manual for your model: 4322500 Whirlpool Self-Cleaning Slide-In Gas Ranges.pdf
    I don't see a E2 F3 on the list, I see F3 E2.
    F3 E2=Bake range over temp
    1. Measure sensor value (between connector pins) between 1000 Ω @ 32 F (0 C) and 2697 Ω @ 900 F (482 C) (approximately 1080 Ω @ room temperature). If measurement does not correlate to real temperature, disconnect power, replace sensor and refer to steps 3-5. Also measure from sensor connector to sensor casing for possible short.
    2. Trace wires and connectors to sensor, from control, then from sensor back to control. If all connections made and no wire damage, refer to step 3.
    3. Disconnect power for longer than 30 seconds.
    4. Reapply power and observe for longer than 1 minute.
    5. If failure remains, disconnect power, replace control, then go back to step 4.
    Nov 2007
    Gresham,Or
    I know, thank you....however the E2 is first then F3 and like I said before it will go off even if we haven't cooked...like at 1:30am I am so confused on where to go for help. We have found nothing about this situation.
    Ok, I'm not sure then, you may have to contact Whirlpool to send a tech. out on yours.
    Dec 2015
    Minnesota
    Default Whirlpool Gold Accubake System Error Codes for Model # GW395LEGQ3
    The link above does not open and that website is restricted.
    I also receive error messages on the Whirlpool Gold Accubake System Model # GW395LEGQ3 - Serial # IMK1998673, currently receiving error code E1 F5 after attempting to use the self cleaning feature and the oven remains in the locked position (tried holding "START" for 5-seconds and unplugging the range, but that didn't resolve the issue).
    It would be great to get an full error code list if you have one available (in the event that the current issue can be resolved).
    Your assistance would be greatly appreciated.
    Regards,
    Shanny
    Oct 2004
    E1-F5 says....Solenoid not operating or latch switch failure.
    Tech sheet attached.
    Attached Files Attached Files
    http://www.applianceaid.com/
    Appliance Repair Aid
    I fixed it for you.
    Jeff also posted the tech data sheet too.
  1. Whirlpool Gold Accubake power shuts off in the middle of baking
    By Wireshark43 in forum Whirlpool/Roper
    Last Post: December 28th, 2013, 03:36 PM
  2. Whirlpool gold accubake gas oven PF
    By Mrsluib in forum Whirlpool/Roper
    Last Post: November 4th, 2013, 10:26 PM
  3. Whirlpool gold accubake oven
    By Tyrman in forum Whirlpool/Roper
    Last Post: January 1st, 2013, 12:20 PM
  4. Whirlpool Gold Accubake
    By Gimpster1 in forum Whirlpool/Roper
    Last Post: July 7th, 2010, 08:17 PM
  5. Whirlpool Gold Accubake GMC305PDB6
    By TRENTGSTL in forum Whirlpool/KitchenAid
    Last Post: January 28th, 2008, 10:36 PM
