Results 1 to 7 of 7
Thread: F9 Error on my Kenmore Elite Gas Stove
    Nov 2007
    McHenry, IL
    Default F9 Error on my Kenmore Elite Gas Stove
    Kenmore Elite Slide In Stove: HELP
    I tried to clean my oven last night. I set the cleaning time and decided to cancel it. Then an F9 error message appeared. Now my lock light blinks and I can not turn it off. My oven will not work now due the the blinking light.
    I unplugged it from the power outlet and once I plugged it back in the problem continued.
    Whats the model# of your range? Its located either inside the door, or on the bottom frame when you pull out your storage drawer.
    Jul 2006
    F9 is usualy the door lock circuit. Try putting it back into self clean. If that doesn't work I'll need your model number.
    OWNER RICK'S APPLIANCE REPAIR
    REFRIGERATION SPECIALIST
    Nov 2007
    McHenry, IL
    Default Serial Number
    790 45714 100
    Nov 2007
    McHenry, IL
    Jul 2006
    Check the switch on the motor latch assembly. It's #89 in this diagram.
    Thats usually what I find bad as well.
    Here's the one for your model:
    Manufacturer's Number: 318095937
  1. Kenmore Elite HE3 Gas Dryer No Heat
    By billjes in forum Sears Kenmore
    Last Post: June 26th, 2007, 11:27 AM
  2. Kenmore Elite Gas Drier taking too long to Dry
    By mvetree in forum Sears Kenmore
    Last Post: May 9th, 2007, 02:07 PM
  3. FIXED: Kenmore Elite Gas Dryer error code e2
    By pdougan in forum Sears Kenmore
    Last Post: January 12th, 2007, 10:33 PM
  4. Kenmore Elite HE3 Gas Dryer Electric
    Last Post: September 21st, 2006, 02:29 AM
  5. Replies: 7
    Last Post: September 25th, 2005, 11:53 PM
