Results 1 to 10 of 10
Thread: kenmore gas range oven won't light
    Nov 2007
    bealeton virginia
    Default kenmore gas range oven won't light
    My Kenmore model 362.75381891
    The oven does not always light. the glow bar comes on, sometimes it gets very gassy smelling. The broiler works and the top burners work
    Usually I can get it on when I light one of the top burners when I turn on the oven
    My husband can probably fix it if I had instructions on how to test whatever
    Jul 2006
    Start by looking at the holes in the side of the burner where the igniter is. Make sure they are clear. The gas has to blow on the igniter to light. If some of the holes get blocked, it won't always light.
    OWNER RICK'S APPLIANCE REPAIR
    REFRIGERATION SPECIALIST
    Nov 2007
    bealeton virginia
    Default gas oven
    Ok the oven is sealed- does it come out with screws? Do you have a manual?
    Jul 2006
    Look on the floor of the oven in the back. Remove the two screws holding it down. Lift it up from the back and it will come out. There is a metal flame shield sitting on top of the manifold. Remove the two nuts in the center, one in the front and one in the back. Lift it off and you will see the manifold and igniter.
    Nov 2007
    bealeton virginia
    where are the quick reply icons?
    Jul 2006
    next to "quote"
    Nov 2007
    MD
    I have a similiar issue with Model 362.7131190.
    The safety valve is opening, I hear and smell gas. I chicken out after 5 min's without ignition. The ignitor is new and is pulling 3.2 Amps. I have cleaned the burner tube. What is keeping this from lighting?
    Secondly - Is there any safety that shuts off the gas in this situation? Or will it continue to flood the area with gas until - KABOOM?
    Jul 2006
    Sometimes you have to put the range back together when you test it. There's not enough gas in a concentrated area to light. If the holes in the manifold next to the igniter are clear and the flame shield is on top of the manifold it won't go KABOOM. The worst you would hear is a loud Wooosshhh
    Nov 2007
    MD
    Everything was put back in place. I've had flames shoot out about a foot from the bottom when I hear the Wooosshh! Any knowledge of a safety (flame sensor?) to shut off the gas in a situation like this?
    Jul 2006
    No, there is no senser. Check to make sure the small set of holes next to the igniter are clear but be careful not to enlarge them. If you close the broiler door it will probably be ok. Do you have a gas regulator on the range? If not you can put one on.
  1. Kenmore gas oven slow to heat up
    By t7044wa in forum Sears Kenmore
    Last Post: June 23rd, 2016, 07:58 PM
  2. Kenmore gas range - oven burners won't light
    By squirkie in forum Sears Kenmore
    Last Post: January 19th, 2012, 07:45 PM
  3. Replies: 2
    Last Post: April 11th, 2007, 08:53 AM
  4. Year Old Kenmore Gas Oven Won't Light
    By maggie2853 in forum Sears Kenmore
    Last Post: March 15th, 2007, 03:27 PM
  5. Kenmore gas oven 362.72295790 oven won't light
    By bandit1trucking in forum Sears Kenmore
    Last Post: November 20th, 2006, 01:36 AM
