Results 1 to 4 of 4
Thread: Maytag washer is burning drive belts.
    Apr 2006
    chicago
    Default Maytag washer is burning drive belts.
    Hello, I have a long-winded series of events for my Maytag top loader washing machine, but I'll just keep this short with the following question:
    Model: Maytag LAT8714AAM
    Serial: A0315312KZ
    When the washer is running on spin cycle, the drive belt is not turning and excessive friction builds up between the motor pulley and the drive belt, it makes a ton of burnt rubber smoke and ruins the belt. So, should the drive belt be slowly turning when the machine is in spin cycle??
    I have a long write-up that I'll post here to give more specific info. I appreciate anyone who can give me some tips and advice. Have a happy Thanksgiving! Thank you.
    Yes, the drive belt should start to slowly turn your inner tub when its draining.
    Tilt your washer back and try to turn your drive belt by hand, if it seems hard to turn, then you either have something caught between your outer tub & inner tub, or your main tub bearing has gone bad and is seizing up.
    Apr 2006
    chicago
    Hi Jake, thanks for the reply. I will give it another test tonight, but i remember the large transmission/drum pulley turning freely with no belts connected, but I'll check it again. If the drum bearing is failing then is that a replaceable part?
    Thanks for the response I appreciate any advice I can get.
    Yes, its replaceable, but its a big job to do it.
    LAT8714AAM
    Diagram#7 Part location#23 & #29 is the 2 parts that would need to be replaced.
    Here's a guide on how to change them:
    http://www.applianceaid.com/tub_seal_replacement.html
  1. FIXED: Maytag MAV8000AWW Washer - Burning Smell
    By kapdan in forum Maytag/Magic Chef/Admiral/Jenn-Air
    Last Post: December 30th, 2014, 11:02 AM
  2. Maytag Performa pav3200aww washer DRIVE PROBLEM
    By w_runk in forum Maytag/Magic Chef/Admiral/Jenn-Air
    Last Post: November 24th, 2007, 10:13 AM
  3. Maytag mav7000aww Top loading washer loud clicking noise during spinning
    By alan509 in forum Maytag/Magic Chef/Admiral/Jenn-Air
    Last Post: September 23rd, 2007, 06:18 PM
  4. Kenmore washer intermittent burning smell
    By mvmartin in forum Sears Kenmore
    Last Post: February 10th, 2006, 01:40 AM
  5. FIXED: Maytag Top Load Washer puzzler (MAT25CSAAW)
    By Jimmy in forum Maytag/Magic Chef/Admiral/Jenn-Air
    Last Post: May 25th, 2005, 05:58 PM
