Results 1 to 4 of 4
Thread: Loose refrigerator door handle
    Nov 2007
    St.Louis
    Default Loose refrigerator door handle
    A diagram of the refrigerator door is attached.
    I would like to tighten my refrigerator door handle on a Whirlpool ED25DQ but can not find a way to get at the screws(#5) holding the handle holder(#12) to the door.
    I have been able to remove the
    trim end caps (#29);
    handle / handle holder screws(#34)
    But neither the trim nor the handle is moving.
    Any help you could give me would be much appreciated!
    Dane
    Hi Dane,
    The #16 & #7 trim just pry off, they may be on tight, just use a little force.
    Nov 2007
    St.Louis
    Thumbs up Thanks Jake, it worked!
    Jake, thanks for the tip. You gave me the extra confidence to pry the trim a little harder.
    Step by step for anyone else attempting this...
    1)Remove the silver cap (#29) from the top of the white trim. Even though is might be pretty tight, I would suggest trying to rock it back with your thumbs before taking a tool to it. It is, after all only plastic.
    Note: The trim(16) is secured to the trim track(28) by bumps in the trim. There are about 5 bumps on each side about 3 inches apart. These bumps are stagered on each side to make the removal a easier. (They are not right across from each other)
    2)To start taking the white trim from the silver trim track insert a screwdriver in where the silver cap was, and gently pry the trim from the track. This should get the trim off the first few inches of the trim track.
    3)I loosened the rest of the trim using a putty knife. I placed the end of the putty knife between the trim and the trim track in the lower section of the area I had already loosened and poped track out a little more, past the next nub. I then went to the other side of the track and repeated the process, altenating from side to side poping the trim out nub by nub.
    This might sound like a long process, but in reality took less than 3 minutes even being very careful. After all, the trim is rather thin and can be bent or scraped somewhat easily.
    4)Tighten screws on handle (#5)
    5)Pop trim back in, starting on the bottom.
    6)Replace silver caps.
    If I can do this, you can too.
    Good job Dane.
  1. Kenmore Elite S/S Door handle comes loose
    By Dave0747 in forum Sears Kenmore
    Last Post: December 27th, 2007, 02:51 PM
  2. GE Front Loader noisy/drum loose
    By rriggs9000 in forum GE/Hotpoint
    Last Post: July 28th, 2007, 12:29 PM
  3. I found Skate Plate completely loose, water leak, and big bang.
    By tommmm in forum Whirlpool/KitchenAid/Roper/Estate
    Last Post: February 14th, 2007, 12:32 AM
  4. GE WWSE5240GWW Spanner Nut Coming Loose
    By sonofdonald in forum GE/Hotpoint
    Last Post: February 4th, 2007, 12:11 PM
  5. Agitator Loose - should I be concerned?
    By taysue in forum Whirlpool/KitchenAid/Roper/Estate
    Last Post: August 31st, 2005, 09:41 PM
