Results 1 to 3 of 3
Thread: Gas oven wont turn off.
    Nov 2007
    MN
    Default Gas oven wont turn off.
    Model Number: JGBS16WEP1WW
    Brand: GE
    GE XL44 JGBS16WEP1WW
    The oven will not turn off. It happened once a year ago and cleared itself, but now it stays on until the gas is shut off.
    Last night I went to boil a pot of water. The oven had stuck on earlier in the day and I had the oven knob off and the gas turned off for about 4 hours. When I turned the gas back on the stove top burner worked just fine, but the oven turned on too, and the temp kept on rising past what my oven thermostat could register.
    I just now tried it again and the oven will not turn off. I cut the gas, but the igniter is still glowing an hour later. What should I be looking at?
    Thanks, Carl
    Nov 2007
    MN
    Replaced thermostat, all is good.
    Glad you found the problem and fixed it Carl.
    Here's the oven thermostat for this model, in case others with this model need to order it as well:
    GE WB20K8 Oven Thermostat Assembly - AppliancePartsPros.com
  1. dryer wont turn/or turn on
    By glack in forum Maytag/Magic Chef/Admiral/Jenn-Air
    Last Post: January 14th, 2013, 09:45 PM
  2. magic chef gas oven #S64H-4TKXW wont turn on
    By ajsr4limbs in forum Maytag/Magic Chef/Admiral/Jenn-Air
    Last Post: October 24th, 2011, 10:03 AM
  3. Replies: 3
    Last Post: September 17th, 2011, 12:46 AM
  4. Dual Fuel Range oven wont turn on (79045714100)
    By ICaughtFire in forum Sears Kenmore
    Last Post: November 8th, 2009, 11:31 PM
  5. Jenn Air wall oven W304008 wont turn off
    By sun45 in forum Maytag/Magic Chef/Admiral/Jenn-Air
    Last Post: April 3rd, 2008, 10:02 AM
