Results 1 to 4 of 4
Thread: Maytag QuietSeries 300 problem - some buttons don't work
    Dec 2007
    Oregon
    Default Maytag QuietSeries 300 problem - some buttons don't work
    The model # is MDBTT70AWB. It's one month past the 1 year warranty. Every alternate button on the left side of the control panel seems to be dead. So I can't get Heavy Wash, I can get Normal Wash, etc. Based on information in this forum, I located the diagnostic sheet behind the bottom panel. But I'm not sure how to measure the pin-pin resistance on that ribbon cable. I have an ordinary RadioShack multimeter, and the lead tips aren't fine enough to cleanly contact only one trace on the end of that cable. Also, I'd need to hold 2 leads to 2 trace ends, and press the button on the front panel. Any tips on how exactly I should measure those resistance values would be helpful.
    Regardless, I'm thinking this is probably a bad control panel, and not a problem with the board? I ran an Auto cycle after I first saw this problem, and it ran fine. I could go ahead and order the control panel, but if I could confirm that those buttons aren't working, I would feel more comfortable ordering it.
    Also, I assume the ribbon cable comes with the front panel? I couldn't see how it was attached at that end, it seemed to go into the plastic housing, and if it needs to be soldered, I'm pretty sure that's beyond my skill as well.
    Thanks in advance.
    Yes, Its your control panel assembly, I had one do this exact same thing a few months ago, and the control panel fixed it.
    Here's the control panel for your model:
    Manufacturer's Number: 99003409 - Control Panel
    icon
    If you purchase parts from our links here and you install them and it doesn't fix the problem, you have a 30 day full refund.
    Dec 2007
    Oregon
    Thanks a lot for the quick reply and the link. One question - does the ribbon cable come attached to the control panel? So all I have to do is plug it into the connector on the PCB?
    Edit: Hmm... it shows as out of stock, but says it'll ship in 5-6 days. Not really sure what that means, maybe they expect to get it in soon? I'll go ahead and place the order.
    Yes, the ribbon cable comes attached to the control panel, so you just plug it in the connector on your PCB.
    Yes, I noticed it was out of stock as well, but they should be able to ship it in 5-6 days.
  1. Which Maytag QuietSeries 300 Control Board?
    By PJM in forum Maytag/Magic Chef/Admiral/Jenn-Air
    Last Post: November 7th, 2007, 07:46 PM
  2. Im new: problem with maytag quietseries 300
    By Eddiegsr in forum Maytag/Magic Chef/Admiral/Jenn-Air
    Last Post: April 11th, 2007, 11:57 AM
  3. Maytag 1502ARW problem
    By Katiemay in forum Maytag/Magic Chef/Admiral/Jenn-Air
    Last Post: August 30th, 2006, 01:49 PM
  4. Maytag Refuses To Solve Problem
    By Mike B in forum Maytag/Jenn-Air Reviews
    Last Post: July 14th, 2006, 01:01 AM
  5. Maytag washer hopping problem
    By Ken Brekke in forum Maytag/Magic Chef/Admiral/Jenn-Air
    Last Post: March 7th, 2006, 01:53 AM
