Results 1 to 6 of 6
Thread: Bosch dishwasher
    Dec 2007
    ft worth texas
    Question Bosch dishwasher
    I have a Bosch dishwasher model # SHV4803UC/U07
    had sink backup over weekend and fill the dishwasher, tech who installed did not install an air vent, got clog taken care of and turned on dishwasher it pumped out the water but of course did not run, have been readiing the postings, I think the float switch needs to be reset, have taken out filter and cleaned also, thought I could get to it under filter screen, not, do I have to pull out the dishwasher and access it from the side?
    thanks
    Dec 2007
    ft worth texas
    Default bosch diswasher
    ok so I pulled the dishwasher out removed left side panel and found float switch and reset
    Dec 2007
    ft worth texas
    Default bosch dishwasher float switch
    ok so reset and turned on was working fine, turned it off to reinstall under counter, got everything back and turned back on not filling with water again, pulled back out and checked everything (water on) all water vacumned up out of pan with shop vac does the diswasher itself need to be reset currently it is still out. any suggestions most helpful
    Unfortunately, I don't work on Bosch products. Jeff1 has a good Bosch help page here:
    http://www.applianceblog.com/mainfor...read.php?t=268
    In the first post.
    You can also message him and see if he knows.
    Dec 2007
    ft worth texas
    Default resetting float switch bosch dishwasher
    thanks anyway, but I got it fixed, after flipping through the other postings with similar problem.
    after I pulled the dishwasher out and removed the side panel again, making sure all water was out of the very bottom pan, I took about 3 gallons of water and put into tub, after I shut the door the washer started cycling again, I left it out this time to be sure and it completed the wash cycle. reinstalled all looks fine.
    Sounds good.
  1. [FIXED] Bosch Leaking Dishwasher
    By mpadberg in forum Bosch
    Last Post: March 7th, 2016, 06:07 AM
  2. Bosch Dishwasher "groaning"??
    By pointnshoot in forum Bosch
    Last Post: April 21st, 2011, 11:45 AM
  3. Bosch Dishwasher Power
    By 10009575 in forum Bosch
    Last Post: October 11th, 2007, 06:38 AM
  4. Bosch Dishwasher Problem
    By DanM in forum Bosch
    Last Post: July 2nd, 2007, 10:48 PM
  5. Bosch Dishwasher will not fill with water
    By sparks70b in forum Bosch
    Last Post: October 11th, 2006, 07:12 PM
