Page 1 of 3 123 LastLast
Results 1 to 10 of 25
Thread: Clean between glass on oven door
    Jan 2008
    Fremant
    Default Clean between glass on oven door
    We have a three year old Kenmore Model 790 electric range. Some liquid must have dripped down inside the door. Now the glass has a streak that we can not remove from the glass on the inside or outside, so the streak must be between the two layers of glass that are the window in the oven door. How can I get to it to clean it and what should I use?
    We would need your complete model#, its located on the bottom of your range when you pull your storage drawer out, it should be on the left or right side leg frame.
    Jan 2008
    Fremant
    Our complete model number is 790.96324401.
    Here's the parts diagram for your oven door:
    http://c.searspartsdirect.com/lis_pn...0038-00004.png
    Just remove the 4 screws#60B and then that glass frame should come off, you may want to have someone help you hold the glass while you take the frame off.
    Jan 2008
    Fremant
    Default Cleaning Glass in Oven Door
    Thank you. We did it this morning. First we removed the door from the hinges and laid it on the kitchen table. Thanks to your help, taking the outside glass off so we could clean the inside surfaces of both panes of glass was much easier than I expected.
    Good job, glad you got it cleaned.
    Aug 2010
    Yellowknife, NT
    We just bought our Kenmore stove and imagine that...we haven't even had it a month and we already have a drip between the 2 Panes of glass...help!! Our Model number is: 790.688432
    Please double check your model#, that one doesn't show as good.
    The model# tag is located at the very bottom front on the left or right side after you pull out the storage drawer.
    Aug 2010
    Yellowknife, NT
    lol I reversed the first 2 numbers, it's C970-688432.
    Canadian model? Oh boy, can't look that one up, we don't have access to Canadian models here.
    Jeff may be able to help you, he lives and has a appliance shop in Canada.
    You can go to Jeff's q&a section here:
    Question and answer forum entrance for Appliance repair helps
  1. Kenmore model 790.96612401 oven door problem
    By hammesd in forum Sears Kenmore
    Last Post: November 11th, 2015, 09:31 AM
  2. Replies: 11
    Last Post: July 18th, 2011, 01:55 AM
  3. Kenmore Elite Oven Door Glass Shattered
    By Jimbo3322 in forum Sears Kenmore
    Last Post: October 3rd, 2007, 02:46 AM
  4. Broken glass on Kenmore oven door
    By mandapanda in forum Sears Kenmore
    Last Post: September 25th, 2006, 08:06 PM
  5. GE Range:Replace oven door glass?!
    By leeberg in forum GE/Hotpoint
    Last Post: September 29th, 2005, 09:49 AM
