Results 1 to 10 of 18
Thread: GE Washer no spin and burning smell
    Jan 2007
    Default GE Washer no spin and burning smell
    I have a GE Model GWSR3090T9WW that recently gave off a burning smell. I took the front panel off to find the motor pully smoking hot. I tried to start the spin cycle again and the belt attempts to spin along with the motor pulley but in the end all that's spinning is the the fitting at the bottom of the motor pulley. I tried to physically spin the drum and it won't budge. Any thoughts?
    Thanks;
    Todd
    Apr 2006
    S. Central PA
    Possibly something between the basket and tub.. You will need to remove the top tub cover/splash ring
    Jan 2007
    There's nothing between the tub and drum, could it be the bearing?
    Jan 2007
    Powered off I can move the motor pulleys freely.
    Apr 2006
    S. Central PA
    Does the pulley under the trans turn in 1 direction easy and the other way does it turn and spin the basket with slight effort
    Jan 2007
    Correct. The basket will turn in the opposite direction with more force than the other direction.
    Jan 2007
    I took the clutch off and took it in and they said that it looks good. I tried turning the basket manually again and noticed that the pulley stiffens up when the tranny is at the same position everytime and I hear a clunk or metal scraping at the same time. I could be losing my mind, I don't know. If there were clothes on the shaft would the basket spin at all. After I put the clutch back in I started it up and she spun for a bit and then stopped. I was also able to turn the basket using the agitator from inside the basket. What do do from here?
    Sounds like you will need a new transmission assembly.
    Check your owners manual, most have a 5 year warranty on the transmission itself, you just have to pay labor to have it installed.
    Jan 2007
    The unit is 10 years old. Do you happen to have a diagram of how to install the trany?
    Yup, here's a step by step manual to install a new tranny:
    http://www.applianceaid.com/genew2.html
  1. Kenmore Elite Catalyst washer won't drain & spin
    By Brittgee in forum Sears Kenmore
    Last Post: July 26th, 2010, 10:05 PM
  2. Whirlpool Ultimate Care II washer - no drain or spin
    By emmittbarks in forum Whirlpool/KitchenAid/Roper/Estate
    Last Post: January 19th, 2008, 11:44 PM
  3. Ge washer not spinning burning smell
    By sun45 in forum GE/Hotpoint
    Last Post: October 29th, 2006, 10:37 PM
  4. Whirlpool washer won't agitate...but will spin
    By steph23 in forum Whirlpool/KitchenAid/Roper/Estate
    Last Post: May 8th, 2006, 07:38 PM
  5. Amana Washer - Burning smell during spin
    By loriscottz in forum Amana
    Last Post: August 8th, 2005, 11:52 AM
