Results 1 to 8 of 8
Thread: Washer won't spin or agitate
    Mar 2008
    California
    Default Washer won't spin or agitate
    I have a Kenmore series 70 model # 110.20712990 that just makes a grinding noise when it reaches the spin cycle. It does drain the water, but sounds like my old VW bug after I played mechanic on it...... ANy help would be appreciated.
    Mar 2008
    California
    Default Photo of what I found by turning it on its side
    WHen I moved the washer, I found a peice of white plastic beneath it. Being the "detective" I am, I turned the machine on its side and found a broken white "thing" I have no clue what I am looking at so I attached a photo. Hopefully someone can make an identification from what I have.
    Mar 2008
    California
    OK not fair...answering my own questions. The motor coupling was trashed, broken into peices. I will hopefully pick up a new set tomorrow. Is there anybody that thinks that this is the problem? or did I stumble across an unrelated issue?
    THanks
    Your better than you thought, answering your own questions.
    Yup, from that photo looks like your motor coupling is broke.
    Here's the motor coupling for your model:
    Manufacturer's Number: 285753A
    285753A
    Read #2 and #5 here on how to access and change it:
    http://www.applianceaid.com/procedures.html
    Before you put the new one on, turn that gearcase shaft clockwise and counterclockwise to make sure its not locked it and turns fairly easy. I've seen gearcases lock-up and snap that puppy clean off.
    Mar 2008
    California
    THanks!! I will check the gearcase shaft as soon as I get home from work.
    Sounds good, let us know the outcome.
    Mar 2008
    California
    Good to go!! two successful loads of laundry with no trouble. THe spin cycle seems to stop more abruptly than I remember, but the wife is happy
    Good job fixing it, glad its running again.
  1. maytag washer doesnt spin or agitate
    By sun45 in forum Maytag/Magic Chef/Admiral/Jenn-Air
    Last Post: March 17th, 2007, 12:40 PM
  2. kenmore 80 series washer no spin or agitate
    By brooklynjim in forum Sears Kenmore
    Last Post: August 22nd, 2006, 11:56 AM
  3. GE Washer Fills but won't agitate, spin or drain.
    By jaytango in forum GE/Hotpoint
    Last Post: May 14th, 2006, 12:50 AM
  4. Whirlpool washer won't agitate...but will spin
    By steph23 in forum Whirlpool/KitchenAid/Roper/Estate
    Last Post: May 8th, 2006, 06:38 PM
  5. Frigidaire front load washer won't agitate or spin
    By bigwilliecrash in forum Frigidaire/Electrolux
    Last Post: March 14th, 2006, 05:54 PM
