Results 1 to 10 of 20
Thread: Dripping icemaker
    Feb 2008
    San Jose, CA
    Default Dripping icemaker
    Model Number: 106.70262990
    My icemaker is dripping on my Kenmore Coldspot 106.70262990 refrigerator.
    Here's a pic:
    What should I inspect/replace?
    -n.
    You'll need a new ice maker module.
    Here's the ice maker module for your module you can order:
    Manufacturer part#W10122536 is RepairClinic item#1373103
    W10122536
    To change it, take your ice maker out by taking the 2 screws out from the top, and the 1 on the bottom, that mounts it to your freezer wall, unsnap the electrical connector.
    Then remove the front cover, just unsnaps. Then remove the 3 screws that hold the module in place as seen here:
    http://www.applianceaid.com/icemaker-modual.html then remove the metal bar that snaps into that plastic sensor piece on the module.
    Jan 2007
    MARYLAND
    Jake, What causes this? I have a similar problem on my Treo. It drips some every time it ejects ice and I get a small clump daily. Thanks, Bob
    On the module style ice makers (Whirlpool, Maytag Family, Sub Zero) the printed circuit in the module head often wears and the contacts become too long and allow the icemaker to over fill = new ice maker or new module head.
    This is from Jeff's site, www.applianceaid.com
    Jan 2007
    MARYLAND
    Jake, One more question. The model is Kenmore 596.73502202. I did a parts search at repairclinic.com and it likes like I have to replace the entire ice maker. Is that correct? There's no sub-assembly? Thanks, Bob
    Yes, thats true on your model Bob.
    You can save some money, I found it on sale for currently $89 here: Manufacturer's Number: D7824706Q
    Jan 2007
    MARYLAND
    Thanks again Jake! So this fits a kenmore Treo? Just making sure as the maker is listed as Amana and or Maytag. repairclinic.com had suggested replacing the water inlet valves, which cost almost as much as the entire ice maker. Bob
    Yes, this is the one for your model, your Kenmore 596 model is made by Amana.
    You water inlet valves should be fine.
    If case you ever need them, you can order them.
    Primary water inlet valve: Manufacturer's Number: 12544002
    Water valve kit: Manufacturer's Number: 12002193
    Jan 2007
    MARYLAND
    It looks like the new one is working OK. That was the easiest icemaker repair I've ever done. Whoever designed that one and the freezer did something correct.
    Bob
    Excellent Bob, good job fixing it.
  1. Dripping Icemaker
    By Kizzy in forum Whirlpool/Roper/Estate
    Last Post: February 16th, 2013, 08:41 PM
  2. new icemaker dripping
    By rreale in forum Whirlpool/Roper/Estate
    Last Post: July 16th, 2012, 08:45 AM
  3. Whirlpool Roper IceMaker Dripping
    By J&T in forum Whirlpool/Roper/Estate
    Last Post: January 5th, 2011, 12:56 AM
  4. [FIXED] Icemaker Level Arm Broken Off - Icemaker never stops is also noisy
    By Emoto in forum Maytag/Magic Chef/Admiral/Jenn-Air
    Last Post: December 2nd, 2010, 12:55 PM
  5. GE GSS22JE Icemaker dripping condensate
    By emunandu in forum GE/Hotpoint
    Last Post: March 29th, 2008, 02:33 AM
