Thread: Kenmore 106.56569400 fridge side warm - evaporator keeps frosting up
    Jun 2007
    Clinton Twp., MI
    Default Kenmore 106.56569400 fridge side warm - evaporator keeps frosting up
    The fridge side of our Kenmore never seems to get below 40 degrees. The freezer side holds steady around 0-5 degrees. At least once a month, the fridge approaches 50 degrees and I have to take the back panel out of the freezer to melt all the ice off of the evaporator with a hair dryer. It gets totally clogged with ice so that no air could possibly move thru it. Any ideas as to why this happens once a month?
    Denny
    Hi Denny,
    There should be a diagnostics sheet behind your front bottom kickplate grill, it just snaps off, pull hard.
    If your heater element and defrost thermostat test good, then it has to be a bad control board.
    You would need a volt/ohm meter to check for continuity on the heater element and defrost thermostat(while frosty).
    #33 here:
    http://www.searspartsdirect.com/part...4027-00011.png
    is your heater element and #35 is your defrost thermostat. Both are located inside your freezer section behind your inside freezer lower back panel.
    #6 here:
    http://www.searspartsdirect.com/part...4023-00010.png
    is your main control board that controls your auto-defroster
    Sears wants $208 for it, You can get it here for $150:
    Manufacturer Part# 8201660
  1. Kenmore Coldspot freezer perfect, fridge warm
    By nandof in forum Sears Kenmore
    Last Post: July 1st, 2007, 10:49 AM
  2. Replies: 7
    Last Post: June 23rd, 2007, 09:47 AM
  3. Replies: 18
    Last Post: May 18th, 2007, 11:17 AM
  4. Kenmore Elite SxS warm on Fridge side
    By BWinMinnesota in forum Sears Kenmore
    Last Post: September 17th, 2006, 11:56 PM
  5. Replies: 4
    Last Post: April 4th, 2006, 01:52 PM
