Results 1 to 2 of 2
Thread: Premature ice harvest on KitchenAid side-by-side
    Mar 2008
    Sunnyvale, CA
    Question Premature ice harvest on KitchenAid side-by-side
    I have a 2.5 year old KitchenAid side-by-side model KSCS23INBT00 with an ice maker problem a bit different than what I have read about in the other threads. I have read the factory repair manual for the ice maker (Job Aid Part No. 4322658A) and performed the suggested tests. Optical test OK. Jumpered the thermostat on the ice maker and heater came on, ice ejector fingers moved as expected and tray was filled with water. Jumper removed at point specified in test instructions. No error codes signaled on the LED. Everything looks good, but...
    Within an hour the ice maker tries to harvest. The heater comes on and melts the just half-frozen cubes and, strangely, the ejector fingers rotate from the so-called home position (up in the air) only until they point nearly straight down and then they stop. Subsequently, the water in the tray freezes around the ejector fingers and nothing more happens forever after. I have been through this several times now, thawing out the ice maker in the sink between tests.
    For the record, the water dispenser works fine and I just replaced the water filter. I don't see any broken teeth on the main gear.
    I would like help with two questions, please.
    1. Do I simply need to replace the thermostat, which I believe is a relatively inexpensive part? (RepairClinic item 2942). I realize I have to use special mastic to mount a replacment thermostat.
    2. I see that there is a new manufacturer's part number for the whole ice maker (W10122502, RepairClinic item 1373091). Is this an improved version that I should consider buying to both fix the immediate problem and head off future problems?
    Thanks for any light you can shed on this situation.
    Yes, they have upgraded that ice maker, the problem was the motor, they have increased the power so it doesn't stop anymore when the ejector fingers are down.
    Here's the ice maker Part#W10122502 you can order:
    Manufacturer part#W10122502 is RepairClinic item#1373091
  1. Ice Maker Issues - KitchenAid Superba KSCS25I
    By rhayward in forum KitchenAid
    Last Post: August 31st, 2011, 02:29 PM
  2. KitchenAid KSCS25FKSS02 Ice Maker Issue
    By drtomsawyer in forum KitchenAid
    Last Post: February 12th, 2008, 03:28 PM
  3. Whirpool Conqest Gold Side by Side Ice Maker Problem
    By tadpole88 in forum Whirlpool/Roper/Estate
    Last Post: September 21st, 2007, 12:29 PM
  4. ice maker wont harvest ice
    By TJCFAC in forum Sears Kenmore
    Last Post: May 14th, 2007, 10:38 AM
  5. Incomplete Ice Harvest Cycle
    By cynergy in forum Refrigerators & Freezers
    Last Post: December 12th, 2006, 04:36 PM
