Results 1 to 4 of 4
Thread: Kenmore Elite HE3-bearing assembly
    Apr 2008
    Delaware
    Default Kenmore Elite HE3-bearing assembly
    Model Number: 110.44832202
    I have read through much of the archives and see that this was a common problem with the Fridgedaire models and a rare one with the Whirlpool models, but I guess we are the lucky few.
    Our HE3 set is not quie 4 years old (July 04) and the basket completely seized up a couple days ago, would not spin or rotate. My husband has completely disassembled the machine and found one of the bearing assemblies completely in pieces. There were two, one is pressed into the outer tub and seems to be fine. Like I said, the other was loose bearings and torn metal laying inside the machine. In reading old posts, I realized that we had warning (the jet engine noise) but did not pay attention to it.
    The problem we have run into, is that Sears or the other repair shops he has spoken with do not know which part the bearing comes on since it is not available by itself. Since it was already broken there is no way for us to know if it was attached to the outer tub or to the basket. Does anyone have experience with this repair?
    Apr 2006
    S. Central PA
    The bearings go to the rear tub and comes as a assembly.. its best to replace the rear tub and basket together since the basket shaft usually gets damaged when the bearings go bad...but the price is steep...
    Sears has the pts for 508.00 (R.Tub/Basket/Pulley Nut)...PartsPros.com has them for 450.00...
    Apr 2008
    Delaware
    I was afraid you would say something like that!! ARGH !!!!!And yes you called it, the basket shaft does have a small gouge on it from where the bearing let loose. i was pretty sure i could dress it out, but.....i will probably replace both parts.thanks for the input
    Here's the rear tub bearing assembly for your model:
    Manufacturer's Number: 285984
    285984
    Here's the basket assembly, Part#8182232:
    Manufacturer's Number: 8182232
  1. Kenmore Elite HE3 drain problem
    By ninez in forum Sears Kenmore
    Last Post: February 6th, 2012, 12:37 PM
  2. Kenmore Elite HE3
    By Tagman886 in forum Sears Kenmore
    Last Post: January 27th, 2010, 07:52 PM
  3. Need Help with Kenmore Elite HE3 Dryer Model 11082832100
    By luvgingerella in forum Sears Kenmore
    Last Post: May 4th, 2009, 11:42 PM
  4. Kenmore Elite HE3 Gas Dryer No Heat
    By billjes in forum Sears Kenmore
    Last Post: June 26th, 2007, 10:27 AM
  5. Broken seal Kenmore Elite HE3
    By leesandy in forum Sears Kenmore
    Last Post: September 28th, 2005, 11:03 PM
