Results 1 to 7 of 7
Thread: Amana SXD25AW ice chute wont close
    Apr 2008
    Chicago
    Default Amana SXD25AW ice chute wont close
    My parent's ice chute won't close on their ice dispenser. They've kept using it broken by just pullig the lever out themselves, therefore shutting the flap. If looked at a couple of diagrams and I can't figure out exactly what is needed for this repair. Any suggestions? Thanks.
    You would need the ice door chute kit.
    Here's the one for your model:
    Manufacturer part#R0000447 is RepairClinic item#822937
    Do you need help taking the dispenser frame cover off to access it?
    Apr 2008
    Chicago
    Thanks for the help Jake, I've never tackled one of these before so any more links or directions you could send would be much appreciated.
    Ok,
    Here's the parts diagram for the front dispenser:
    Take off the grill#9, then pull off the cap#16, then remove the 2 screws#15, then the cover#10 should just slide off, slide it to the right. On some models it un-snaps/pops off, but I believe on this one it slides off.
    Here's the parts diagram for the inside of it where your door chute is:
    Remove the 2 screws#29, then that whole assembly should pull forward out of the way. Then you should be able to get to your door chute#24.
    Apr 2008
    Chicago
    Replacing the door chute didn't do the trick. Looks like I have a bad Airpot? Just guessing, but it appears to be some sort of airtight little pod that helps the door return to the shut position. Does this sound right or am I way of on my guest-imation? Here's the link
    http://www.repairclinic.com/referral...=1265&N=127211
    or maybe I need one of these do-hickeys
    http://www.repairclinic.com/referral...=1265&N=673162
    I'm gonna go tinker with it until I get some educated guesses. Thanks.
    Just to restate the problem (a little clearer maybe since I have it apart). The ice dispenser arm is not returning to the original starting position after it is pressed in. It stays to the back against the cavity wall, therefore keeping the flap in the open position. The water dispenser arm has two metal spring tension brackets that keep it in the original spot. the ice arm does not as far as I can tell, so that is where my guessing comes in because it isn't real clear to me what returns the ice dispenser arm to the original position. Thanks again.
    Apr 2008
    Chicago
    Done with my tinkering.
    The door flap chute was actually ok. I replaced it anyway because the new one seemed to seal tighter, plus it was a cheap part.
    The actual problem was the airpot device. This thing...
    It seems it's only function was to prevent the flap from slamming back shut hard. Not sure what went wrong with it, but it was preventing the spring pressure from the flap from closing everything. After I noticied that the chute door closed property with the device removed, I simply lubed up the part that slides into the plastic housing. Works fine now. Hopefully my learning process might help someone else down the road. Thanks again Jake for the help.
    Ok, sounds good, glad that fixed it, thanks for updating us on it to help others as well.
  1. Amana ice maker problem
    By sarek007 in forum Amana
    Last Post: September 12th, 2007, 03:42 PM
  2. No Ice chute door on Whirlpool Conquest?
    By birchtreemike in forum Whirlpool/Roper/Estate
    Last Post: July 19th, 2007, 08:38 PM
  3. In door ice dispenser flap will not close
    By pgluckey in forum GE/Hotpoint
    Last Post: July 5th, 2007, 09:20 PM
  4. Replies: 2
    Last Post: May 6th, 2007, 10:19 PM
  5. amana s+s ice chute frosting up
    By johnny cooke in forum Amana
    Last Post: December 20th, 2006, 09:26 PM
