Thread: Frigidaire Classic Seires
    Apr 2008
    Tennessee
    Default Frigidaire Classic Seires
    I have a Frigidaire Classic Seires model# 316233860 . First I had a F9 error when trying to preform a self cleaning. I took the back panel off and checked the wiring it looked ok. I powered on and held down the Clear/off button and then I received 100 and door locked. Now it has the time and says door locked the timer buttons work but none of the "Bake" or other buttons work the range also works. Help me Jake!!
    Please check your model# again, I can't find any info on that one. The model# tag is usually located on the bottom of your range after you pull out the storage drawer on the bottom frame.
    So, now it says locked and the oven door isn't not locked?
    Did you try to unplug it or turn the breaker off to it for 5 minutes to see if it will reset?
    Apr 2008
    Tennessee
    Default correct model
    Here is the correct model number FEF366CCB . I turned the braker off and now I get the F9 error again.
    Here's the tech data sheet for your model:
    ftp://ftp.electrolux-na.com/ProdInfo...16218513en.pdf
    F9 says:
    Control has detected a problem with the Motor Door Latch Assembly.
    Check the wiring. Replace the Motor Door Latch Assembly if necessary.
    You will need to order a new latch motor assembly, here's the one for your model:
    Manufacturer part#316464300 is RepairClinic item#1191763
    316464300
  1. Please help with Frigidaire model numbers
    By Bruce Humphrey in forum Frigidaire/Electrolux
    Last Post: November 29th, 2007, 07:25 PM
  2. Black grease smudges on clothes - Frigidaire LEQ332DS0
    By dixieagle in forum Frigidaire/Electrolux
    Last Post: July 23rd, 2007, 03:37 PM
  3. Frigidaire Double Wall Oven or Repair Existing GE Wall Unit
    By knittermom in forum Frigidaire/Electrolux Reviews
    Last Post: February 8th, 2007, 12:39 PM
  4. Wiring for my new Frigidaire
    By mgoogs in forum Frigidaire/Tappan/Electrolux
    Last Post: December 7th, 2006, 06:50 AM
  5. Frigidaire Classic (PN316218504 (0301)) Broiler Flame is Low
    By amgc230k in forum Frigidaire/Tappan/Electrolux
    Last Post: October 23rd, 2006, 02:40 AM
