Results 1 to 6 of 6
Thread: Timer not working DU850DWGB2?
    Apr 2008
    Hendersonville, NC
    Default Timer not working DU850DWGB2?
    Our Whirlpool dishwasher DU850DWGB2 is doing all cycle functions beside moving through the cycle by itself. I assume the timer is bad. Any ideas? Do I have to replace this expensive part?
    Thanks for any ideas.
    Nov 2007
    Portland, OR
    When you say doing all cycle functions, do you need to manually advance it to operate, or does it fill and wash but the timer stalls during the wash cycle?
    Apr 2008
    Hendersonville, NC
    If I manually move the timer through the cycle the dishwasher will perform the step, until I manually move ti to the next step. For example it got stuck in heat dry and it heated a whole night long and melted all plastic lids, which were close to the heating element. The timer does not move through the cycle by himself at all. I hope this answers your question Brian
    Nov 2007
    Portland, OR
    If it's not moving, then it looks like a new timer is in order. The only other thing you should check for piece of mind would be to get to the timer and check for voltage to the timer motor, and make sure all the wires are seated in the connector. The door switches would need to be actuated and you should read 110vac approx. between the tan/red and white/violet wires leading to the timer motor. But you are most likely going to end up needing a new timer.
    Apr 2008
    Hendersonville, NC
    Thank you Brian!
    Timer changed, everything is perfect again now.
    Nov 2007
    Portland, OR
    Glad I could help.
  1. Replies: 8
    Last Post: January 17th, 2014, 07:03 AM
  2. Replies: 3
    Last Post: September 24th, 2007, 12:37 AM
  3. Whirlpool Direct Drive Timer Problem
    By chatparle in forum Whirlpool/KitchenAid/Roper/Estate
    Last Post: January 29th, 2007, 01:29 PM
  4. Kenmore 110.96273100: if not the Timer, what else?
    By doh-boy in forum Sears Kenmore
    Last Post: January 18th, 2007, 11:04 PM
  5. Dryer timer not working
    By nothandy in forum Whirlpool/KitchenAid/Roper/Estate
    Last Post: October 9th, 2005, 08:49 AM
