Results 1 to 6 of 6
Thread: Whirl Ult.Care Washer leaves H20 in tub
    Apr 2008
    PA
    Question Whirl Ult.Care Washer leaves H20 in tub
    Hello,
    My old faithful Whirlpool Ultimate Care Heavy Duty Super Capacity Plus (model # LSR8233EQ1) has left a high level of water in the basket. It's making a sound like it is trying to pump out, and it seems to be going through (or trying at least) all the cycles. As you can imagine, it had a bit of a burning smell when I went to check on it. Any idea if this may be repairable...hate to give up on a good and faithful servant !
    Thank you very much,
    April
    Its possibly something stuck in your water pump. I would check that first.
    Also check your motor coupling, to make sure it didn't break.
    Read #2 and #4 and #5 here on how to access these:
    http://www.applianceaid.com/procedures.html
    Here's the water pump for your model:
    Manufacturer's Number: 3363394
    3363394
    Here's the motor coupling:
    Manufacturer's Number: 285753A
    285753A
    Apr 2008
    PA
    Thumbs up Cha-Ching!!
    Hi Jake,
    Thank you so much--you were dead on with the object in the water pump...it was a nickel causing the chaos! The couplers looked just fine, so my hubby put her back together again and she's been happily a washin' ever since!
    Thank you very much...your help is greatly appreciated!
    Best regards,
    April
    PS--that Cha-ching was a tip in your jar!
    Sounds good, glad you found the nickel in the water pump and got it removed.
    Thanks for the tip.
    Apr 2008
    PA
    Hi Jake,
    Hope you are well. I have a follow up question for you. This washer is completely rusted in the frame around the bleach mechainisim, etc and surrounding and is now falling apart and shaking badly when spinning, but the motor and pump (just replaced last week) is still in good working order. Is it possible at all to just replace the framework and keep it in operation?
    April
    Hi April,
    Is it the cabinet or top itself rusting or the washer base assembly?
    Here's the washer base assembly for your model:
    Manufacturer's Number: 285771
    285771
    Here's the top assembly that your bleach mechanism is mounted on:
    Manufacturer part number 3949476 is RepairClinic item number 547270
    3949476
  1. Washer tub won't center
    By iowafarmer in forum Maytag/Magic Chef/Admiral/Jenn-Air
    Last Post: March 8th, 2011, 09:05 PM
  2. Kenmore 110.26902691 black junk in washer tub
    By cknh in forum Sears Kenmore
    Last Post: February 18th, 2008, 11:30 PM
  3. GE Washer WHSB8000B0WW leaves marks on clothes
    By lsparkie in forum GE/Hotpoint
    Last Post: November 6th, 2007, 11:21 AM
  4. need Tub Seal for Kenmore 417.41042000 Washer
    By Adelescomp in forum Sears Kenmore
    Last Post: May 21st, 2007, 12:34 PM
  5. Replies: 4
    Last Post: February 5th, 2007, 08:54 PM
