Results 1 to 2 of 2
Thread: Whirlpool Duet Washer GHW9150PW4 leak
    Apr 2008
    Carnation WA
    Red face Whirlpool Duet Washer GHW9150PW4 leak
    After investigating the leak for my Whirlpool Duet Washer GHW9150PW4, I discovered by partially removing the door seal that there was a hidden tear in the seal. The tear is at a crease tucking in next to the water inlet. I duct taped it for now (no leaking, whew!). However, I am thinking I might need to order a new seal. I notice that the inner side of the seal is attached to the drum of the machine. This I did not take out, in that I don't want to not be able to put it back. Before, I purchase a new one (can you give me the part #, and most inexpensive place to order?), I would like to know how the repair process, to make sure I can do it myself. I looked at the online repair manual for the 9100/9200 and it does not address this issue. Also, because the seal rubs against the water inlet creating the tear, I am concerned that it will just happen again. How do I repair it so that I don't have the same thing happening in 1 1/2 yrs (age of machine)? Thank you!
    Here is a guide you can follow:
    http://www.applianceaid.com/image/Duet_boot_door.jpg
    Here's the cheapest bellows I found you can order:
    Manufacturer's Number: 8182119
    8182119
  1. Whirlpool Duet Washer - Water leak issue
    By soundjunkie in forum Whirlpool/KitchenAid/Roper/Estate
    Last Post: April 28th, 2012, 10:57 PM
  2. F20 error on BRAND NEW Whirlpool Duet Steam Washer
    By mikemilw in forum Whirlpool/KitchenAid/Roper/Estate
    Last Post: January 22nd, 2008, 09:16 AM
  3. Whirlpool Duet Washer
    By Jane T in forum Whirlpool Reviews
    Last Post: September 21st, 2007, 09:56 PM
  4. Whirlpool Duet Washer leak
    By Madzoo in forum Whirlpool/KitchenAid/Roper/Estate
    Last Post: April 8th, 2007, 11:16 AM
  5. whirlpool duet washer not totally draining
    By suedeluca in forum Whirlpool/KitchenAid/Roper/Estate
    Last Post: December 15th, 2005, 09:15 AM
