Page 1 of 3 123 LastLast
Results 1 to 10 of 21
Thread: NAV3330EWW leaks and screams
    Mar 2008
    MA
    Default NAV3330EWW leaks and screams
    I have a NAV3330EWW that is less than 2 years old. The other day is leaked (during the rinse or spin cycle) and now it makes a terribly loud scream when it spins. My wife also said the laundry room smelled like burnt rubber.
    I am guessing the belt needs to be replaced. But the leak has me much more worried.
    Its possibly your water pump making the noise and leaking.
    Did you remove the lower access panel#16 here: Parts for Amana NAV3330EWW: Cabinet & Base Parts
    Here's the water pump for your model:
    Whirlpool 27001233 Washer Pump
    Mar 2008
    MA
    Default Any way to test the pump
    Is there any way to test the pump to see if it the culprit? Or do you just have to replace parts til the problem goes away?
    Yes, you can remove the water pump, it mounts with 3 screws under the motor, but you need to remove the motor assembly first.
    Here's a help link if you need to remove the motor and pump: http://www.applianceaid.com/amana-wash.html#belt
    Your water pump is #14 here: Parts for Amana NAV3330EWW: Motor, Pump and Idler Assembly Parts
    Here's the belt for your model, in case its burned up pretty bad:
    27001006 Drive Belt
    Mar 2008
    MA
    Default Removed the motor and pump...
    I removed the motor and pump. Is there a way to determine if the pump is the culprit? Should the pump spin freely, or should there be some resistance?
    The belt looks okay. Not shredded or burnt.
    Tim
    If you can get a flashlight and look inside the pump for foreign objects, then turn the impeller thats inside it by turning the plastic piece were the motor shaft connects to it, It should turn freely.
    Mar 2008
    MA
    Default I don't think it is the pump...
    I reassembled the motor and belt without the pump. I ran a spin cycle and it is still very loud. I guess that means the transmission, or a bearing, or the motor. I guess I'll try running without the belt to eliminate (or implicate) the motor.
    Yes, try running the motor alone without the belt on it.
    Mar 2008
    MA
    Default Not the motor...
    I removed the belt and ran a spin cycle and the loud growl went away. Now what?
    Transmission? New washer?
    Any thoughts on putting it back together and running it the way it is until I decide what to do. I understand there is a risk of it leaking again.
    On the topic of leaks...is it uncommon for a washer to leak intermittently? We ran a couple loads after the small leak and don't think it leaked.
    Mar 2008
    MA
    Default last post of the night...
    After looking through the archives, I found a post that had similar symptoms. It turned out that the hub (or tub) seal and bearing kit solved the problem. It sounds like a moderately difficult repair job, but I'm up for it.
