Results 1 to 8 of 8
Thread: Whirlpool Duet - Wet clothes at end of cycle
    Apr 2008
    IL
    Default Whirlpool Duet - Wet clothes at end of cycle
    I am trying to troubleshoot a Whirlpool Duet GHW9100LW that has very wet clothes when the cycle is done.
    The size of load doesn't matter. (Same results with any size load)
    I haven't seen any error codes.
    I have cleaned the course filter on the drain pump. I did notice when I did this and went to "Drain/Spin" the speed would initially accelerate and then slow spin and then rock and then slow spin and repeat the rocking/slow spin.
    I ran a Diagnostic Test and everything seemed to be OK (it spun at high speed).
    I am looking for a suggestion on what to do next.
    Thanks in advance
    Aug 2005
    Milbank, South Dakota
    Check and clean out the trap for the water pump.
    Apr 2008
    IL
    Already did that (I have cleaned the course filter on the drain pump.) and backdrained the drain hose and made sure the pump rotated freely.
    Does it do this on all loads?
    Does the machine vibrate alot when its spinning slow then high speed?
    Apr 2008
    IL
    It is wet on all loads.
    It was vibrating excessively at high speed with loads prior to this being a noticable problem. No excessive vibration noticed lately or when I ran the diagnostic test (unloaded)
    Ok,
    Do the shocks all look ok?
    Some other possibilities is the CCU or Motor or Motor controller board.
    How old is your washer? If you don't know, you can post the serial# and I could tell you.
    Apr 2008
    IL
    Default Culprit identified?
    The shocks seem OK. When I removed the back cover, there was a lot of belt wear. The belt looks like it was centered on the pulley but is now on the inside edge of the pulley and looks like it has worn a groove in the drum. There is a lot of play in the pulley (1/4-1/2") possibly hitting the drum and some rotationally. I am thinking a bad bearing. Does this sound plausible?
    Serial # CSP1510671
    Yes, it sounds like your tub bearing is bad.
    Unfortunately, Whirlpool doesn't sell the bearing alone, when you order the outer tub it comes installed.
    On your model#GHW9100LW you should have another number after the W.
    It does make a difference, as they make 2 different outer tubs for this model.
    These tub assemblies are expensive from $250 and up. If you wanted to just replace the bearing alone, I would suggest taking the bearing out of the outer tub(No Easy Task) and taking it to a local bearing shop in your area to see if they can match it up.
    Here is the online repair manual for the Duet:
    http://adcxns1.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/eab852a13fbc842085256aa200643dd6/$FILE/Duet%20Job%20Aid.pdf
  1. Duet Gas Dryer: cannot turn off after auto cycle
    By PRK in forum Whirlpool/KitchenAid/Roper/Estate
    Last Post: October 22nd, 2007, 11:56 AM
  2. Whirlpool Duet Washer
    By Jane T in forum Whirlpool Reviews
    Last Post: September 21st, 2007, 10:56 PM
  3. Replies: 4
    Last Post: March 5th, 2007, 10:59 AM
  4. Whirlpool Duet Dryer Marking Clothes
    By alp in forum Whirlpool/KitchenAid/Roper/Estate
    Last Post: February 27th, 2007, 02:26 PM
  5. whirlpool washer screeches at end of spin cycle
    By Mikeze in forum Whirlpool/KitchenAid/Roper/Estate
    Last Post: February 22nd, 2007, 02:36 AM
