Results 1 to 7 of 7
Thread: Kenmore 106.53659300
    May 2008
    Bellevue, WA
    Default Kenmore 106.53659300
    Hi, I have a 2003 Kenmore model # 106.53659300 and it started acting funny so i started troubleshooting and I have a question. I noticed a few days ago that the fan was running all the time. I noticed today that the refrigerator was getting warmer, and stuff at the top of the freezer was starting to thaw. I vacuumed the coils underneath as they were very clogged and I also took the cover off the back of the freezer and thawed all of the ice off of the coils in there. I noticed that there is a little silver disc about the diameter of a quarter and about 3/4 of an inch thick that clips onto the refrigerant line that comes into the freezer. This part has a pink and brown wire attached to it and it looks like the blue cap popped off and the pink wire was no longer soldered to the part inside the cylindrical part. I should also note that a few months ago the ice maker stopped working until I put a cup of hot water under the water inlet tube in the ceiling of the freezer and thawed out the pipe so water could flow to the ice maker. Any other things I should be looking at or could the part I described be causing these problems. I hate to throw parts at a problem but the part I described clearly needs to be replaced anyway.
    May 2008
    Bellevue, WA
    Looks like PN#2196155 Bi-Metal Defrost. is the bad part. what causes this to fail.
    Yup, thats the defrost thermostat(Bi-Metal), I've seen that happen many times on all brands, I don't know what causes it, but a new one will fix it.
    Here's the one for your model you can order:
    (The manufacturer has replaced part#2196155 with this item, part#2319914.) (Manufacturer part#2319914 is RepairClinic item#1194651.)
    Aug 2005
    Milbank, South Dakota
    I see that a lot too.
    Here is a photo of just what your talking about.
    http://appliancejunk.com/forums/inde...sa=view;id=347
    Good photo AJ, Thats exactly what it looks like.
    May 2008
    Bellevue, WA
    Hi Folks, i replaced the part listed several months ago and the fridge and freezer work great but I am noticing that the water inlet tube over the icemaker is freezing up. I have taken a blowdryer and warmed it up a few times now and that seems to temporarily fix the problem of the icemaker not working but I am wondering what causes the rubber tube to freeze.
    It was a design flaw issue.
    I run into that tube freezing problem alot on the Kenmore/Whirlpool/KitchenAid models. There is a heater kit that you can install, it does fix the issue.
    Part#4389174
    Comes with instructions.
  1. Kenmore 110.42822203 bearing
    By Zebrafive in forum Sears Kenmore
    Last Post: March 25th, 2008, 12:43 AM
  2. Kenmore Fridge (freezer) not cooling properly
    By mattpaul in forum Sears Kenmore
    Last Post: April 16th, 2007, 09:02 AM
  3. Kenmore 94152 melting synthetic fleece
    By swienke in forum Sears Kenmore
    Last Post: December 23rd, 2006, 04:16 PM
  4. Kenmore 665.15932000 versus Maytag MDB8751
    By russell g in forum Sears Kenmore
    Last Post: October 17th, 2006, 12:21 PM
  5. Another Kenmore with no Heat
    By tickedntexas in forum Sears Kenmore
    Last Post: February 6th, 2005, 08:05 AM
